I have had problems lately with my distributor rotor coming loose. Also the adapter that the rotor attaches to. MSD Billet dist. in a BBC. Before I use loctite, which I don't believe should be necessary, has anyone expierenced this? I dont' know if a vibration/harmonics would cause this. Any ideas? Thanks,
Kevin Tiedemann S/ST 145T |
Liked 11 Times in 8 Posts
Do the screws have conical washers on them? My old rotor had flat washers, new one came with funky looking conical washers which I believe is to eliminate loosening. Joe
Joe Buchanan SS/BX 3117 |
Liked 229 Times in 99 Posts
I had to use loctite on mine. Just a drop.
Floyd Staggs 787 SST |
Conical washers and a drop of blue loctite....
Danny Waters, Sr / 73 Duster "340" |
I had this same problem on Labor Day...and I had the conical washers...now I use loctite AND the washers...we'll see if that holds...
It was strange...never had this problem before...
Ted Barnes 1511 HR |
Liked 886 Times in 238 Posts
Just because of this thread , I deceided to look at my rotor this weekend . ...Guess what,the rotor screws with the conical washers were tight, BUT the screw that holds the rotor adapter to the shaft was coming loose ,and it had been loctited [blue].....Got a dose of "red" this time. ..............Tom
I have had this same problem on both of my distributors and solved it with blue loctite and have not had a problem in 4 years now.
Thanks for the advice, Loctite it is.
