Old 11-09-2010, 04:49 PM   #21
Duane Dagostino
Default Re: What would be the min size truck to tow 24 foot enclosed?
Tweaker...check your pm's
Duane Dagostino 1821 S/C, S/G
Duane Dagostino is offline   Reply With Quote
Old 11-11-2010, 01:16 PM   #22
Michael Pliska
I wouldn't worry at all about buying a 100k+ mile modern diesel, as long as they have maintenance records, and preferably have few or zero modifications. With tuners/chips they can definitely run them hard enough to hurt them although even that is rare.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 11-11-2010, 04:47 PM   #23
Tweaker
Tweaker's Avatar
Cool I'll try to find a 250 then diesel or something like that. thanks all
IHRA #2X41
http://khracing.projectrhyme.com
Tweaker is offline   Reply With Quote
Old 11-13-2010, 09:42 AM   #24
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Possible, yes. Safe, that's the question.With a 1/2 ton you will get pushed around and you won't feel all that stable. I used to tow with a 1/2 ton till I had to panic stop once. Scared the crap oughta me. Went right down on Monday and bought a 2500 HD. It's my daily driver, a little more expensive to drive, but I feel a lot safer.
Floyd Staggs 787 SST
Old 11-13-2010, 09:55 AM   #25
Bob Verwold
Bob Verwold's Avatar
My suggestion would but a 3/4 or 1 ton, THEN get a junker to drive around town..
Bob Verwold is offline   Reply With Quote
Old 11-13-2010, 10:33 AM   #26
Floyd Staggs
Originally Posted by Tweaker View Post
Is it bad to get a gas motor in a 250 or 2500 ?
I have the 2500 HD with the 8.1 L motor. It gets 11 mpg around town and 9 towing. I should have bought the diesel.
Old 11-13-2010, 03:20 PM   #27
Play400
I have an 04 Ford FX4 Screw with 18" wheels and it is only rated to pull an 8500# trailer. I believe it has the 2nd highest towing capability of all the F150s. Not a problem with my open trailer, +6000# loaded but sure throws a damper into getting an enclosed. Mind you that new 5.4 pulls like crazy, never down on power and I have no problem with brakes etc but do have a good controller and equalizer hitch. Have yet to use the bars or anti-sway link with this set-up
Play400 is offline   Reply With Quote
Old 11-27-2010, 10:06 AM   #28
THE LEGEND
I have a 06 Duramax @65 mph on hwy will avg 19 mpg. @70 it will drop to 15
Towing 9-14 depending on trailer and speed.
What I'm saying is go overkill on the tow vehicle and sacrifice some on the dailey driver thoughts. You never know you may buy a bigger trailer in the future.
To answer you original question, you can do it with a half ton or a suburban just be careful
Chip
THE LEGEND is offline   Reply With Quote
Old 08-22-2012, 07:56 AM   #29
joe cool
Liked 5 Times in 3 Posts
I've mentioned this before but you can buy a single axle semi, IH or Columbia for a lot less than a pickup, you can't drive it everyday but it has suspension and brakes you don't have to worry about.
If you want the big sleepers are available also,just my opinion, I could be wrong.
joe cool is offline   Reply With Quote
Old 08-22-2012, 08:48 AM   #30
Bob Verwold
I went that route, the down side is ya need a CDL license. Almost anything in that range is going to be over weight (26,000) with a trailer..........
