Old 11-27-2010, 12:05 PM   #1
Glenn Quinn
Glenn Quinn's Avatar
Default Throttle stop on EFI
I am looking to add a throttle stop to run SG next year. The car is an AMC running on Methanol and runs 8.80’s all out. Has anyone run a throttle stop with EFI?
Thanks in advance,
Glenn
Glenn Quinn is offline   Reply With Quote
Old 11-27-2010, 10:16 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: Throttle stop on EFI
Glenn, answered your post over on the bullet, but thought I'd chime in here as well. We're going EFI this year to run SC, using an inline stop. I know of a couple of people who've tried it, and reportedly had some success.
But I'm going individual runner/plenum (separate intake tubes/blades/injectors for each cylinder) that I don't know that anyone has tried. Everything I know about the system, powered by a FAST Xfi, is that it should be a screaming combination, with lightening fast throttle response, great tunability, and deadly repeatability. But only time will tell.
PM if you want more info.
Chris
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 11-28-2010, 07:28 PM   #3
racerguy
Call fastmanefi.com
racerguy is offline   Reply With Quote
Old 12-01-2010, 12:31 PM   #4
TS310C
We ran a FAST EFI setup for years in both the super classes and T/S. I ran a base stop until we went to 2 throttle bodies. The base stop worked good, but with the inline stop you are able to tell the computer what your throttle position is which can help depending on how you have your program set up.
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
