Old 02-06-2011, 06:52 PM   #1
TS310C
Default Water Pump connector
Does anyone know where I can get another electrical connector for my CSR water pump? We are re-wiring a car and need the part of the quick disconnect electrical connector that stays with the car. I believe it is the female portion. I have looked on Jegs and Summit and can't find it. They might know if I called them, but I haven't done that yet.
Thanks!
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
Old 02-06-2011, 09:11 PM   #2
63corvette
Liked 360 Times in 104 Posts
Default Re: Water Pump connector
Radio Shack has all the connectors.
I purchased a CSR and an MSD pickup connectors both at Radio Shack.
You might need to find a bigger store as some of the small ones do not always have a good selection.
Good Luck With The Search
Rick
63corvette is offline   Reply With Quote
Old 02-07-2011, 02:34 PM   #3
TS310C
I'll have to go by a store and ask. They don't have anything that I can find on their web site. I think before I go there, I will check out or local speed shop. At least they would know what I was asking for. The last time I went to our local Radio Shack, the guys working there were barely smart enough to tie their shoes.
Ryan Koener
S/G 310C
Old 02-07-2011, 02:48 PM   #4
Chris Williams
Chris Williams's Avatar
The trick in Radio Shack is to NOT talk to anyone. They most often mis-direct you. Most of them have a big gray set of drawers with all kinds of connectors, plugs, etc. in them. Just go there and hunt around.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 02-07-2011, 10:45 PM   #5
63corvette
After thinking about the connectors one of the two I bought was marked for a radio controlled car battery or charger depending on which end you needed.
I can not remember whether it was for the CSR or the MSD but one was the radio controlled car plug.
The Radio Shack I went to had dozens of different connectors and had both of what I needed.
One Stop Shop for me which does not happen that often when looking for race parts.
Good Luck with the search.
Rick
Old 02-07-2011, 11:39 PM   #6
Bill Baer
You also could look online a digikey or wayteck.
Old 02-08-2011, 01:40 PM   #7
dbochan
Send a message via AIM to dbochan Send a message via Yahoo to dbochan
Why not convert to a weatherpack type connector. Jegs has a kit from Caspers Electronics #182-103005 Weatherpack Connector Kit for racer price of $62. It has all the connectors and parts you will need to make the connections. It makes borrowing a part difficult, but i like the Weatherpack connectors and have my spare stuff already changed over with soldered connections.
David
dbochan is offline   Reply With Quote
Old 02-08-2011, 02:01 PM   #8
TS310C
I thought about that. I actually have a weatherpak kit, but I want to keep them standard. I have found that it is much easier to keep things with factory connectors if you are going to have to swap them out in a hurry.
Ryan Koener
S/G 310C
Old 02-10-2011, 09:43 PM   #9
voltdr
Liked 100 Times in 51 Posts
That's the BEST advice for anyone going to a Radio Shack. If they ask me if I need help I just say NO. LOL
voltdr is offline   Reply With Quote
Old 02-14-2011, 01:30 PM   #10
dbochan
I found that the SPAL automotive fan that i have has the same connectors. SPAL has a 24" pigtail for $8.95. The connector is a TYCO #926474.
http://www.spalusa.com/store/main.as...ail&item=FR-PT
