Old 03-31-2011, 07:03 PM   #11
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: Traction issues
Before you spend any money, try going the other way with the shocks. Make them stiff on extension, ie hard to pull apart. Make a big move, not just one or two clicks.
Costs nothing, and I think you'll be pleasantly surprised.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 03-31-2011, 09:39 PM   #12
Tony Curcio
I later realized I should make sure it was clear I meant the rear shocks.
Also, the ladder bars' upper hole will usually make the car hit harder, which is probably not what you want in this situation.
Old 04-01-2011, 07:45 AM   #13
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Thanks Tony, I've been brain f#cking this thing for days now and you are probably right. I had some chatter at the last division race and I raised the launch rpm and softened the shocks. That was probably the wrong way to go. I think I have magnified the problem since. I made 2 changes instead of one and lost sight of where i was, I'm going back to my original settings where the 60' were good and go from there.
Floyd Staggs 787 SST
Old 04-02-2011, 08:37 AM   #14
Floyd Staggs
I took the tires back to MT yesterday and they agreed the tires were too hard. They are going to change them out for me. Now I got to get back to my original settings and make some of the adjustment suggested to try to improve.
Thanks for all the suggestions.
