Old 04-21-2011, 10:12 PM   #1
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Carb Jetting ?
OK I need some opinions,or what you are running for carb jets.
Motor is a 468, 13 to 1 compression, 714/714 Lift roller, BB 2 Plus heads, Team G intake, Quick fuel 1050 carb.
I changed the plugs tonight and they were a little whitish, I have 92 square in it now.
I guess I'll need to go to 94 square or higher?
any comment will be apperciated.
Cal
HR 177X
cal is offline   Reply With Quote
Old 04-21-2011, 11:33 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Carb Jetting ?
http://www.dragstuff.com/techarticle...ark-plugs.html
Old 04-22-2011, 09:15 AM   #3
Keith 944
Keith 944's Avatar
is that a 1050 dominator style or a 4150? i have both, i use a little more jet in the dom. 92 sq. 86sq in the 4150. every engine is slightly diff. but you seem very close....
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-22-2011, 11:31 AM   #4
Dave Steltz
Dave Steltz's Avatar
When I ran a Dominator, seemed like the 92 range was good for most smaller BBC's like yours...Maybe invest in an EGT so you can see a little closer, but you should be very close...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 04-22-2011, 04:09 PM   #5
63corvette
Liked 362 Times in 105 Posts
Another important part of jetting is what the adjusted altitude you are running at is and what squirter you use.
You can run a leaner jet and use a bigger squirter to keep it from stumbling at the starting line but you may still be lean on the big end.
Consider more than jet size alone.
My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 04-22-2011, 07:17 PM   #6
wayne sipos
wayne sipos's Avatar
you could try a smaller hi speed air bleed
Wayne Sipos HR 3959
wayne sipos is offline   Reply With Quote
Old 04-22-2011, 09:09 PM   #7
Ron Finney
Ron Finney's Avatar
I had almost the exact same combo except mine was 461 cube....I ran 94 square and have even had 96 in the back in better air....
Good luck!
Ron Finney 396V S/C
Ron Finney is offline   Reply With Quote
Old 04-22-2011, 09:48 PM   #8
cal
cal's Avatar
Thanks Guys
I Put in a fresh set of plugs tonight, and I guess I'll fatten it up a little tomorrow and see what happens.
Cal
HR 177X
Old 04-24-2011, 10:07 PM   #9
jmarkaudio
Jet it for best MPH, that will be the most HP. You can go down one jet size from there and gain a little consistency. Jet requirements can vary depending on the ability of the engine to burn the fuel used, and different fuels can require different jets. The Dragstuff plug article is a good one to learn plug reading.
jmarkaudio is offline   Reply With Quote
