Old 06-17-2011, 07:44 AM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Ez plate system
when running a 4150 carb, there is no better than the adjustable restrictor plate manufactured by Willys and sold through Summit, Jegs and others.
Been using this plate since 2008. Previously to slow my 9 second Chevelle to 10.0 and since 2009 to slow my 8 second Firebird to 9.0 enabling me to run 9.0x all season long at every track I compete.
This 1" 4 hole plate has 18 turns of adjustment in it from fully open 1.75" bore(s) to 1.00"
Each turn is worth ~.04 and can easily kill 100HP.
Nothing to take apart or swap out, couldn't be easier or simplier. Adjustment(s) take a few seconds and as Rich has stated, infinitely adjustable.
Several competitiors and friends are now using it on their 8 to 11 second rides to slow them to make ET cutoffs and/or index classes as well I know of 1 former Division 1 Super Street Champion now using it after hearing about and seeing it in use on my car.
Old 02-21-2012, 11:22 PM   #12
68camaroSS
If you turn it in 3 or so turns, do you have to lean out the carb to make up for the reduced air flow ?
68camaroSS is offline   Reply With Quote
Old 02-22-2012, 07:16 AM   #13
1320racer
1320racer's Avatar
No, I never touch the jetting.
