Old 07-12-2011, 12:59 PM   #21
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Default Re: Single channel O2
Floyd, your using the XFI system? I bought the second FAST O2 for mine after fighting an injector problem through most of 2010, on the opposite side from the one O2 sensor. The second one does not read the same as the one that comes with the XFI system. Not even the same brand sensor. Very dissapointed. My two only agree around 12-1. If you have a carb, not the XFI, their stand alone wide band records air/ fuel versus time, not RPM. Air/fuel versus RPM is much more useful for tuning. I have seen way too many problems with the innovate deal. I personally wouldn't use it.
I have a carb and they have a accessory for RPM. I'm putting that on when I do the second sensor.
Floyd Staggs 787 SST
Old 07-12-2011, 01:33 PM   #22
Ed Wright
Ed Wright's Avatar
That will make it a lot more useful. I know a couple of guys that need that RPM add-on. Guess it's fairly new?
Ed Wright 4156 SS/JA
Old 07-12-2011, 02:00 PM   #23
Floyd Staggs
It hasn't been out long. Check their website. I think it's $160 bucks.
Old 07-12-2011, 03:18 PM   #24
Harry 6674
Originally Posted by Charles Rainey View Post
Harry 6674---That is the unit from Canada that I am testing now. I have one of every sensor he has. So far every thing looks great. I speak with Alan most every day as I try the products. He is great to work with. If you all want to know the results as I test them, let me know. I have a oscilloscope hooked to the units now with dataloggers . Am trying old sensor vs new sensors now on the Dyno
How accurate is rpm pickup? My car isn't running yet so I haven't been able to compare it to the tach. I'm actually useing 2 on a siamised port chevy six with a turbo.
Harry 6674 is offline   Reply With Quote
Old 07-12-2011, 09:16 PM   #25
Charles Rainey
Harry_ i am trying the RPM sensor, egt, and oil pressure sensor now. I am recording off the ignition for tach and comparing it to the dyno rpm which I know to be accurate. I also have scope hooked to it to see also. I will know by end of week after more "testes". Price is reasonable. I have 5 of everything here now just to try. I have it hooked in with a FAST, A INNOVATE, NGK. and 4 of these so I can how it compares with each other. I will data log to the PC so I can map in Excel to make a chart/graph. I will PM you with results.
http://14point7.com/Products.php
Charles Rainey is offline   Reply With Quote
Old 07-12-2011, 10:54 PM   #26
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Originally Posted by Danny Ashley View Post
I have racers call and ask what number to look for and I tell them there's no magic number for everyone. I have customers that range from 12.8 to 13.6 each with fast cars. When you get a wide band Dan, you'll need to go to a test session and work on calibrating your Q-Jet to run the fastest and that will be your "Sweet Spot". Then when you get in different weather conditions your wide band will tell you if you need to lean or fatten it up.
x2! I'm brand spankin' new to EFI, just off my 3rd weekend out. Even if someone runs the same combination as you, there can be something different in either the data collection (type or location of the sensor) or other variables that make things radically different. Ultimately, you have to listen to what the car is telling you on the race track to determine what A/F ratio works best for YOUR setup. Took me til 1st round of eliminations this weekend to figure that out! LOL In the ballpark now, though. I still have a TON of learning to do. One of my issues right now is that I have no basis for what the numbers mean relative to each other. Is half a point in A/F ratio a lot, .25, or is a full point a big swing? Along the same line, I'll need to figure out how much change a single number or single percentage point on the fuel table really is.
Old 07-13-2011, 08:59 AM   #27
Ed Wright
Ed Wright's Avatar
Michael, if your VE table & injector flow rate are setup correctly a 1% change will get you a .1 change in air/fuel. For instance: +.1% will change 13.0-1 to 12.9-1, or -1% would make 13.0-1 to 13.1-1. If your 13-1 and want 12.5-1 subtract 5%. Are you using FAST XFI, or BigStuff3?
Old 07-13-2011, 10:39 AM   #28
Adger Smith
Liked 880 Times in 311 Posts
Michael,
There are sooo... many varaibles in tuning with O2's. I really agree with the idea that there is no "one" number for every combination. Cam overlap is one of the biggest players in what goes out the ex pipe, even low compression vs high compression will make a slight difference in the best O2 number.When you change cam C/L or valve lash or timing on your own combination that you are familar with and have data.. the O2's can change, usually do. The new O2 reading may or may not be the place the engine is happy and making peak power. The old O2 point may not be the best power setting with the changes. You have to search the combination/tune up for what makes the engine happy. A happy engine will usually make you happy because it is making power.
Oh, Please Read the plugs when making changes.... (don't be lazy.. does a plug wrench still fit your hand?) I know, I know it is so easy to take a reading of the data and pound that key board to make changes,,,, but reading the plug is the way to tell what is really going on in the combustion chamber. :~)
Adger Smith (Former SS)
Old 07-13-2011, 11:25 AM   #29
Michael Beard
Michael, if your VE table & injector flow rate are setup correctly a 10% change will get you a .1 change in air/fuel. For instance: +.10% will change 13.0-1 to 12.9-1, or -10% would make 13.0-1 to 13.1-1. Are you using FAST XFI, or BigStuff3?
FAST XFI. Currently running in Alpha-N, closed loop, Target A/F at 12.5. Got it to 13.3 on Run #3 of the weekend at MIR, and it wouldn't get out of it's own way.
Question is, is 13.3 to 13.2 a big jump, is 13.3 to 13.0 a big jump, or is 13.3 to 12.5 a big jump? How much is 1,000' DA change likely to affect the A/F ratio (ballpark)?
Old 07-13-2011, 12:43 PM   #30
Charles Rainey
Adger
I feel as you and others have stated, that there are so many variables, you cannot compare any two motors. What I like to do is have two (2) O2 sensor. One on each side. I do make sure they read the same side too side. But I also like to have at least one EGT on a cylinder that tells me when I have gone unresonably lean. I read spark plugs to keep me honest, but reading spark plugs, is very subjective from one person to another. And on top of that I have customers that just flat cant read spark plugs for crap. So I try to give them as much data as they can download and see. I tell them to always start out rich and lean down and watch time slips. When you get there, write down both EGT and both O2 readings. All this data are nothing but indicators. They are not the Bible. Some of it is scientific and some is black magic. It can mean the difference in .01 and .1 on the time slip.
sorry my .02 worth
