#21 | |
Liked 229 Times in 99 Posts
Floyd Staggs 787 SST |
#22 |
That will make it a lot more useful. I know a couple of guys that need that RPM add-on. Guess it's fairly new?
Ed Wright 4156 SS/JA |
#23 |
It hasn't been out long. Check their website. I think it's $160 bucks.
#24 | |
#25 | |
http://14point7.com/Products.php |
#26 | |
Liked 13 Times in 9 Posts
#27 |
Michael, if your VE table & injector flow rate are setup correctly a 1% change will get you a .1 change in air/fuel. For instance: +.1% will change 13.0-1 to 12.9-1, or -1% would make 13.0-1 to 13.1-1. If your 13-1 and want 12.5-1 subtract 5%. Are you using FAST XFI, or BigStuff3?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 07-15-2011 at 06:06 AM. |
#28 |
Liked 880 Times in 311 Posts
Michael,
There are sooo... many varaibles in tuning with O2's. I really agree with the idea that there is no "one" number for every combination. Cam overlap is one of the biggest players in what goes out the ex pipe, even low compression vs high compression will make a slight difference in the best O2 number.When you change cam C/L or valve lash or timing on your own combination that you are familar with and have data.. the O2's can change, usually do. The new O2 reading may or may not be the place the engine is happy and making peak power. The old O2 point may not be the best power setting with the changes. You have to search the combination/tune up for what makes the engine happy. A happy engine will usually make you happy because it is making power. Oh, Please Read the plugs when making changes.... (don't be lazy.. does a plug wrench still fit your hand?) I know, I know it is so easy to take a reading of the data and pound that key board to make changes,,,, but reading the plug is the way to tell what is really going on in the combustion chamber. :~)
Adger Smith (Former SS) Last edited by Adger Smith; 07-13-2011 at 10:52 AM. Reason: SP |
#29 | |
Question is, is 13.3 to 13.2 a big jump, is 13.3 to 13.0 a big jump, or is 13.3 to 12.5 a big jump? How much is 1,000' DA change likely to affect the A/F ratio (ballpark)?
#30 |
Adger
I feel as you and others have stated, that there are so many variables, you cannot compare any two motors. What I like to do is have two (2) O2 sensor. One on each side. I do make sure they read the same side too side. But I also like to have at least one EGT on a cylinder that tells me when I have gone unresonably lean. I read spark plugs to keep me honest, but reading spark plugs, is very subjective from one person to another. And on top of that I have customers that just flat cant read spark plugs for crap. So I try to give them as much data as they can download and see. I tell them to always start out rich and lean down and watch time slips. When you get there, write down both EGT and both O2 readings. All this data are nothing but indicators. They are not the Bible. Some of it is scientific and some is black magic. It can mean the difference in .01 and .1 on the time slip. sorry my .02 worth |
