Old 07-25-2011, 04:05 PM   #1
Dennismoore
Default Oil leakage
Hello all, This is kind of a generic question so please bare with me. Ive been having a heck of a time keeping the oil in my mopar. After every pass Ive been getting alot of oil up on the valley cover. Today while looking things over I noticed that the crank case evac system is bottoming out on the baffle in the valve cover. When I run the motor the suction is very good. Im wondering if this is the cause for the oil hemerage? Now if I remove these baffles will the evac draw oil out of the motor and out the exhaust? Or do I drill a couple small holes? Any ideas would be very much appreciated..Thanks in advance!!
Dennismoore is offline   Reply With Quote
Old 07-26-2011, 10:39 AM   #2
SCOTT SST2871
Default Re: Oil leakage
You would probably be ok removing the baffles if the breathers arent directly over the rocker arms but you could drill some holes and it should work fine also
good luck
scott fifield
SCOTT SST2871 is offline   Reply With Quote
