Liked 136 Times in 49 Posts
Got the car back together fired it up and it runs great for a little bit then quiet’s with a little puff out the carb. It starts right back up runs nice for a while then does it again. When it is running there is no miss sound good till it does it again.
Running a 7 al ignition box with a MSD distributor. And Accel coil. Any good ideas on where to start looking? |
Liked 13 Times in 7 Posts
Sounds like a vacumn leak maybe. It would run great until you try to idle then it will die.
Richard Grant 4988 STK |
No it will sit there steady at about 1000rpm then with out any thing else changing it hickups and dies. I am thinking must be coil or ignition box related. Or an issue with the the ignition switch. It almost seems like the ignition power skips.
Liked 348 Times in 152 Posts
I would start with the coil, easiest and cheapest (also most likely) part to change.
Phil Molski PMR Performance S/C 1623 |
