Old 08-08-2011, 04:35 PM   #11
Sam Capizzi Jr
Liked 43 Times in 9 Posts
Default Re: Need some input for a 2bbl problem
Originally Posted by Mike Taylor 3601 View Post
I say Billy hit it ,the way the air was there 2bbl car definately would been rich with no changes,rich will not let car crank rpm ,plus converter could'nt flash as high as normal due to power down from air.
How much air hurts mid to higher class stocker, add more if you have 2bbl.,smaller the carb the worse it gets.
Danny
If water temp is that sensitive you may be a shade lean if that little water temp effects you that bad,as temp goes up engine leans more
Mike Taylor3601
Makes sense to me now.
Sam Capizzi Jr. 1301
SS/AS 93 Dodge Daytona
R/SA 73 Dodge Dart
Sam Capizzi Jr is offline   Reply With Quote
Old 08-08-2011, 06:52 PM   #12
Paul Wong
Liked 419 Times in 85 Posts
with all the two bbl cars I have run I would think more timing would help the car out and be a little less sensitive. I have run 273 2 bbl cars in 10000 foot air with 24 barometer.
Paul Wong is offline   Reply With Quote
Old 08-08-2011, 07:46 PM   #13
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Need some input for a 2bbl problem
Mike Taylor3601
Cold engine needs more gas so warm engine needs less.
Cold engine needs more accellerator pump squirt or it bogs.
Think "choke".
Or am I missing something?
A long time ago my bracket car ran flat and missed in the upper rpm ranges when the Holley 4 barrel was jetted several steps too rich - at least 4-5 numbers.
Old 08-09-2011, 02:04 AM   #14
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Need some input for a 2bbl problem
Sam check/add timing. @ Indy Div. race in 2007 I had dad's car with the bracket engine. Car ran 16.25 on a 15.80 index. I told dad over the phone "it's lazy I think it needs timing" He said it won't pick up .3. Well I turned it up the next morning & the car went 15.802! The next weekend we had a Div. race @ Columbus ( i took the 1.82 glide out & put in the 2.08) the car went 15.60...something. Anyway car wouldn't start @ the scales....checked timing 50degrees total!!!! But couldn't start the car once it got hot. I always run 40 degrees in everything else. (BTW had 32 in car @ indy)
Old 08-09-2011, 02:12 AM   #15
Sam Capizzi Jr
Normally I would run more timing but I backed it down after the issues started. Everything going back to normal and taking the car to the local test and tune Wednesday.
R/SA 73 Dodge Dart
Old 08-10-2011, 10:57 AM   #16
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Myron,
I don't see where you missed anything, as engine gets warmer it becomes leaner,colder engine becomes richer.
Mike Taylor 3601
