#11 |
Liked 15 Times in 11 Posts
Thanks for all the help/suggestions gentlemen; I'm still working on this problem and will let you know what the solution was.
#12 |
Liked 241 Times in 80 Posts
Ed:
you are absolutely correct. With the newer ECM's I have been repeatedly been told older laptops are better! With my Bigstuff program I use a Radioshack converter and have experienced no problems downloading from the Big stuff Logger. It sounds like the playback tachs may like the older software as well? Dean |
#13 |
Liked 804 Times in 168 Posts
Interesting thread, actually some of the posts made me feel better, because I have struggled off and on with my progammable msd using that usb to serial port converter cable. Even though I use the same xp laptop, occasionally it doesn't seem to find the usb port. I fooled with it for 20 minutes at indy before i got it to work. I am using the same radio shack cable as Dean.
I am interested in getting another laptop as was described earlier in this thread, what type of store should i look for, is it the local independent type ? and are they usb or serial equipped or both ? Thanks
Dave Casey 1330 STK |
#14 |
Dave:
Once in a blue moon, I will get a comm port error (not recognizing the identified comm port). I then re-activate the same port and it goes away??? must be a computer software glitch I guess? If you are going to use the laptop with race electronics ( I assume u r?), I would stick with the older programs like windows and XP these seem to be far more race electronic/computer friendly. Hell, we both know that I only know just enough to be dangerous to myself! LOL |
#15 | |
Ed Wright 4156 SS/JA |
#16 |
Thanks guys, I will be out to some local shops soon
I too am in the "dangerous around computers catagory" ,
#17 |
Liked 28 Times in 15 Posts
Dave
I use a gadget called KEYSPAN which adds a comm port to a DELL laptop (XP) - Just plugs in the USB port - works fine for last 4 years |
#18 |
Just a quick update on my dilemma, had a computer expert check out my new lap top and it is working correctly (Window 7). Also down loaded tach program from web site and still no go. Next step, down load Window XP and give it a try. I know some of you recommended using the old program but I have the new 7 program and thought it would work, guess I was wrong. Thanks again for all the suggestions, will keep you posted.
#19 |
Here's what I've accomplished so far; borrowed an old laptop with XP, was able to down load but took long time and when I viewed information, it appeared compressed and un-useable. stay tune, further updates to follow.
