Old 10-10-2011, 02:43 PM   #1
CUBEMAN
Default Throttle Stopping
This will be my first venture into S/R racing and was kinda looking for pointers on the T/Stop settings. My car will be approx 1.75 sec under the index. I am looking at going on the stop at .2 or .3 and shifting at .6 and then being on the stop for 1.75 or the approx differance in et on a wide open run to a T/Stop run. Think I may be close or way off ?
CUBEMAN is offline   Reply With Quote
Old 10-10-2011, 03:22 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,249 Times in 988 Posts
Default Re: Throttle Stopping
Search the forum for "stop" and you'll see several helpful threads, this being one of them.
http://classracer.com/classforum/sho...highlight=Stop
Lots of variables (like stop RPM) but get close to find your ratio and go from there. Someone running about the same ET can give you a start point but "your results may vary". Biondo's site also has some good tech tips on running a stop.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-10-2011, 10:05 PM   #3
CUBEMAN
Thanks,will do.
Old 10-11-2011, 09:03 AM   #4
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Throttle Stopping
Look us up in Virginia and Jr will help you get in the right direction. Call me if you need to..
We will be there Thursday nite (early)
Old 10-11-2011, 10:43 AM   #5
cdh124
Send a message via AIM to cdh124
My car will run 8.50 flat out and I am on the stop at .3, shift at .5 and am on the stop about 2.20 with air about 2500-3000ft and 4200 rpm while on the stop. Last year at Virginia in October I was on the stop about 2.5 seconds, hopes this helps.
cdh124 is offline   Reply With Quote
Old 10-11-2011, 10:47 AM   #6
Duane Dagostino
cdh124 is close if your "cruise " rpm's are about 4200. you'll be at 2.50 or so...good luck.
Duane Dagostino 1821 S/C, S/G
Duane Dagostino is offline   Reply With Quote
Old 10-11-2011, 12:09 PM   #7
CUBEMAN
I will go to idle at .2 or .3 and shift @ .6 and thought that with a car that can run at least 1.75 under index that I would start by taking that amount (1.75) and stay on the stop that amount of time for starters. By running a Terminator I will go to idle quickly. I could be all wet here
Old 10-11-2011, 12:19 PM   #8
jmcarter
jmcarter's Avatar
You're assuming a 1 to 1 ratio and that's incorrect...remember you're still covering ground while on the stop. And your RPM on the stop needs to be up in the ~4200 range. Think the others are right with 2.50 being close. Danny and his son can get you close too...better do the test and tune, you'll need 2-3 laps to even get close to your ratio.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-11-2011, 12:29 PM   #9
CUBEMAN
Thanks for helping.
Old 10-11-2011, 01:19 PM   #10
jmcarter
jmcarter's Avatar
One of Biondo's excellent primers on stops, more on their site. They are great to deal with and one of ClassRacer's sponsors BTW.
http://www.biondoracing.com/manuals/...20Stops/TS.pdf
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
