Liked 504 Times in 121 Posts
all right im tossing in the towel and begging someone smarter than i to assist with a 6 year old issue of losing fuel pressure ...
1990 suburban 1984 454 .040 reasonably fresh (has been out twice during this issue) , aluminum intake, RV cam, headers and a Qjet. original tank mounted efi pump replaced with 3/8 copper line to bottom of tank now have holley high perf mechanical pump now have added carter in line small electric pump fuel line is new from bottom of tank to carb, routed away from heat & insulated under hood gas cap has hole drilled in it has 7-8 lbs pressure when started ... however after 1 hour or so of towing im running out of fuel at 2500rpm if i stop i have 1-3lbs of pressure (guage inline under hood) fuller tank seems to help but not 100% temp of truck seems not to be an issue NEVER gets over 210 mostly 180 been 6 years, tanks been out 3 times, ran fuel line twice, two stock mechanical pumps plus holley and electric booster... im ready to put on areomotive 500gph and regulator or sell this thing while SCRAP is high ! help, captain jack
Jack McCarthy 3609 STK "the Captain" |
Liked 216 Times in 77 Posts
These trucks had a problem when they first came out with the baffle in the bottom of the tank coming loose. Back then they would come loose and move around and knock the electric fuel pump loose causing the truck to die and be towed in. I fixed hundreds of them back then at the dealer I worked at. I dont know your setup but maybe yours is loose and causing a problem with your pickup in the tank. I still see one every couple of years. If yours is loose the choices are new tank or find someone with very small arms to go in a put new sheet metal nuts on to hold it back in place.
Liked 552 Times in 215 Posts
Did you install a sock type filter on the end of the fuel line in the tank?
My 1996 GMC started having stalling issues and after going round and round it was fine silt in the sock filter.....it would collapse and lose fuel pressure. This was a Vortec SFI engine and ran with 50 lbs fuel pressure. I was on the hook once and had trouble numerous times before I saw what the issue was. I attributed it to buying gas from some el cheapo stations. The fuel tanker truck might have been there when I got fuel.......stirs up the crap on the bottom of the tank and the cheap sob's never change their filters at the pumps......I found a reddish very fine silt in the sock.....
rob ive removed the pickup and replaced the entire tube to the bottom of tank, wrapped it in screen... did not see (could i see it??) or hear anything loose ?
thanks jack
Liked 43 Times in 29 Posts
Jack just wondering if your problem is possibly a fuel tank that originally was non vented and now with the pump you are running it may require it to be a vented style?
Mark Ruset 2048 STK |
If you pull the sending unit out and look in there its a big piece of white plastic. If there is fuel in the tank it will float a bit and if you slosh the fuel around you will hear the baffle hitting the sides of the tank. If your arms are small you can stick it in the hole and grab ahold of it. If it moves at all its moving too much. I used to be able to get my arm in far enough to put the baffle back over the studs made on the metal tank and start the nuts then I used a long 1/4 extension with a swivel socket on the end to tighten them up. It was a very common problem back then. My thought was that maybe it was floating up and blocking the inlet of your pick up tube.
I'll take a stab at this because I had a similar thing happen to me once.
Did you happen to route the new fuel line right next to the transmission cooling lines by any chance? In my case, the car always ran great on the first pass then once the trans was hot, it wouldn't run hardly at all. Re routed the fuel line and the problem went away. |
Liked 2 Times in 2 Posts
I built a 391 Ford for one of my dads box trucks years ago. He calls me about a week later telling me it would die intermittently. If you let it sit for a minute it would restart and run fine, until it died again.
Replaced the fuel filter, fuel pump, carb, replaced the fuel lines, even the distributor. Finally dumped and cleaned the tank, about twenty little tin foil disk from the top of gas additive bottles came out. They would float around for awhile then get sucked over the intake hole. Have you cleaned the tank throughly?
Tod Lane Swartz & Lane 66 Nova Swartz & Lane 79 H/CM Trans Am |
tank has been off 3 times never notice any dirt, or anything else in it. sock is gone just tube with screen over it with hose clamp holding it on. cap has been drilled to vent. lines are now routed outside frame rail up over inner fender and insulated everywhere under hood...
was wondering about drilling hole in bottom of tank for pickup like a fuel cell... oem always had top exit for safety ?? thanks, keep coming with ideas !
Liked 100 Times in 45 Posts
Sounds like a condition caused by heat is percolating the gas,either in the line or engine compartment.Checked condition of fuel filter?
You can try refridge line sleeves near hot areas in fuel lines are. Just some guesses from a two left handed psuedo mechanic.
Former NHRA #1945 Former IHRA #1945 T/SA |
