Old 11-08-2011, 02:43 PM   #21
69Cobra
Liked 2 Times in 2 Posts
Default Re: 69 Ford Torino Cobra
Alex and 69 Cobra,,,,
Excellent analysis,,,,,,,,,,,,,
Speed Age got the car to run a best of 13.18 @ 109.5 MPH
Average times were in the 13.20's @ 108 MPH.
The Rev-Limiter was put in for a 'reason', obviously...as the test
was controlled and observed by a 'neurotic and extremely nervous'
Ford Dealer representative.
The Speed Age Magazine car-testers came to the conclussion;
* removal of the Rev-Limiter,
* install 7" 'M & H' slicks on 15" x 6" rims
* thinner front tires 7.35 x 15"
* tweak the Holley 780 CFM carburetor
Estimated Performance; 12.80's @ 112 MPH.
LOL Glad I got that one right. If not I would have had to change my screen name
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 11-08-2011, 03:14 PM   #22
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Smile Re: 69 Ford Torino Cobra
My late friend Gene Collins raced a "Box Top" 69 non ram air (flat hood) 428 CJ Fairlane when new after he sold his 271 HP 66 Mustang. He ran in the 10.5 lb class which was H/SA at that time (F/SA today) against the 62 Dodge 383/343 HP wagons. With the 4.30 gears that came in it and everything else as Ford built it he ran 13.30's on OEM street tires. With headers and 7 inch tires he was in the high12.90 and 13.0 range. After we did the heads it ran 12.60's. We then put a 3000 stall 10 inch converter in along with a shift kit in the C-6 and a regrind stocker cam then ran under the record with 12.40's using the OEM stock short block The record at that time was 12.65 set by the "Behemouth" 62 Dodge wagon of Pratt and Burkett. He won enough to pay his bills when he was laid of at work racing at Capitol and Aquasco raceway back then. It was a great car.
Old 11-08-2011, 06:09 PM   #23
Paul Ceasrine
Liked 10 Times in 10 Posts
Forgot to add,,,,,,,,,,,the price of the car as tested.
1969 Ford Torino Cobra 'Hardtop Coupe,,,,,,3208
* Cobra-Jet Package,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,28 7
* Bucket Seats,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,54
* GT Handling Package,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,30
* Tachometer,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,48
* Close-Ratio 4-Speed Transmission,,,,,,,,,,,,,,195
* Drag-Pack,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,155
Total,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,$3977
* Traction Drag-Pack II,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,304
* Drive-Train Drag-Pack III,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,295
* Free-Flow Exhaust Drag-Pack IV,,,,,,,,,,,,,,,,,,,208
* Hi-Rev Engine Drag-Pack V,,,,,,,,,,,,,,,,,,,,,,,,,,,685
Total Cost,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,$5469
Old 11-09-2011, 09:24 PM   #24
Paul Ceasrine
Richard Petty in the 1969 Ford Torino Cobra Fastback 'SportsRoof'.
Richard Petty's first race in the 1969 Ford Torino Cobra
February 1, 1969
Motor Trend 500
Riverside International Raceway (California)
He Won!
Old 11-14-2011, 11:47 AM   #25
Paul Ceasrine
INC.
The 1969 Ford Torino Cobra (proper name).
Available with the;
428 Cobra-Jet, 428/335 HP (Q-Code, non Ram-Air)
428 Cobra-Jet, 428/335 HP (R-Code, Ram-Air)
or
428 Super Cobra-Jet, 428/335 HP (Q-Code, non Ram-Air)
428 Super Cobra-Jet, 428/335 HP (R-Code, Ram-Air)
The standard 428/335 HP Cobra-Jet came through with 3.50 Gears,
and an Open-end differential.
Optional Gear-ratios from the factory; 3.25, 3.90 and 4.30.
4.11 Gears were available, but 'dealer installed only'.
The Super Cobra-Jet engine was available with the Drag-Pack,
which included;
* the special externally balanced 428 engine
* engine oil-cooler
* 3.90 or 4.30 Gears with/Traction-Lock differential
Transmissions;
Wide-ratio 4-speed (2.78 / 1.93 / 1.36 / 1.00)
Close-ratio 4-Speed (2.32 / 1.69 / 1.29 / 1.00)
Clutch-plate (11 1/2")
C-6 Automatic (2.46 / 1.46 / 1.00)
Torque-Converter (1800 RPM Stall-speed)
Tires;
F-70 x 14"
Old 11-14-2011, 01:23 PM   #26
Paul Ceasrine
Magazine Performance Tests;
Road Test
428/335 HP (Q-Code, non Ram-Air), 4-Speed Wide-ratio, 3.50 Gears
Results; 15.07 @ 94 MPH
Motor Trend
Results; 14.90 @ 95 MPH
Car Craft
428/335 HP (R-Code, Ram-Air), 4-Speed Wide-ratio, 3.50 Gears
Results; 14.81 @ 96 MPH
Popular Mechanics
428/335 HP (R-Code, Ram-Air), C-6 Automatic, 3.50 Gears
Results; 14.75 @ 96 MPH
Popular Hot Rodding
428/335 HP (R-Code, Ram-Air), C-6 Automatic, 3.91 Gears
Results; 14.52 @ 97 MPH
Motor Trend
428/335 HP (R-Code, Ram-Air), 4-Speed Close-ratio, 3.91 Gears
(with Hurst Shifter)
Results; 14.50 @ 99.5 MPH
Car and Track
428/335 HP (R-Code, Ram-Air), 4-Speed Wide-ratio, 3.91 Gears
Results; 14.40 @ 101 MPH
Car and Driver
428/335 HP (R-Code, Super Cobra-Jet, Ram-Air), C-6 Automatic, 3.91 Gears
Drag-Pack I
Results; 14.27 @ 99 MPH
Cars Magazine
Drag-Pack I
Results; 14.20 @ 101 MPH
Hot Rod
428/335 HP (Q-Code, non Ram-Air), C-6 Automatic, 4.11 Gears
Dealer-installed 4.11 Gears
Results; 14.09 @ 101 MPH
Super Stock & Drag Illustrated
428/335 HP (R-Code, Ram-Air), 4-Speed Close-ratio, 3.91 gears
Results; 14.04 @ 100.6 MPH
Car Life
428/335 HP (R-Code, Ram-Air), 4-Speed Wide-ratio, 4.11 Gears
Dealer-installed 4.11 gears
Results; 13.93 @ 101.5 MPH
Motor Trend
428/335 HP (R-Code, Super Cobra-Jet, Ram-Air), C-6 Automatic, 4.30 Gears
Drag-Pack I (Press Test car)
Results; 13.88 @ 101 MPH
Detroit Auto News
428/335 HP (R-Code, Super Cobra-Jet, Ram-Air) C-6 Automatic, 4.30 Gears
Drag-Pack I (Press Test Car)
Results; 13.81 @ 102.3 MPH
Super Stock and Funny Car
428/335 HP (R-Code, Super Cobra-Jet, Ram-Air), 4-Speed Close-ratio, 4.30 Gears
Drag-Pack I
Results; 13.79 @ 103.5 MPH
Rodder and Super Stock
Drag-Pack I (Press Test Car w/Slicks)
7" GoodYear Slicks on 14" x 6" rims
Results; 13.59 @ 105.1 MPH
Popular Hot Rodding
428/335 HP (R-Code, Ram-Air), 4-Speed close-ratio, 4.30 Gears
Equipped with; Headers, Aluminum Intake manifold, Dual-point distributor and 7" M & H Slicks
mounted on 15" x 6" rims
Results; 13.27 @ 108.3 MPH
Speed Age
428/335 HP (Q-Code, Super Cobra-Jet, non Ram-Air), 4-Speed Close-ratio, 4.30 Gears
Drag-Pack (I thru V) (Detroit Dealership-prepped car)
G60 x 15" Tires on 15" x 7" rims
Results; 13.18 @ 109.5 MPH
Old 11-14-2011, 02:10 PM   #27
69Cobra
INC.
I believe the title says Ford for make and Cobra for model if I recall. No Fairlane or Torino on it at all.
Kris Rachford
C/S 3032
Old 11-15-2011, 12:49 PM   #28
Paul Ceasrine
1969 Ford Torino Cobra Performance Test;
August 1968
Car and Track
August 1968
Speed and Supercar
February 1969
March 1969
Car Craft
May 1969
Speed Age
February 1970
Super Stock & Funny Car
Old 11-17-2011, 03:08 PM   #29
Marty Burke
Kris is correct. In 1969 the Cobra was its own model, it was neither a Torino or Fairlane
It was also the base car used for the Talladega. To tell the difference just read the 3rd & 4th letter of the vin
EX: 9A42Rxxxxxx
Fairlane Fastback 35
Torino GT fastback 42
Cobra Fastback 46
Formal roof
Fairlane 30
Fairlane 500 33
Torino GT 44
Cobra 45
These cars are starting to get more valuable everyday
Regards,
Marty Burke
1969 Talladega {Maroon}
1969 Talladega {white}
1969 Torino GT {R code 4 speed}
1969 Torino GT {Q code auto}
1969 Cobra R code
1969 Cyclone R code
1969 Cyclone Spoiler II {Gurney}
1969 Cyclone Spoiler {Cale}
All still in the garage
Marty Burke is offline   Reply With Quote
Old 11-17-2011, 03:37 PM   #30
69Cobra
Wow nice collection Mr. Burke. I would also like to add the 69 Cobra hardtop or formal roof was a 45 code for the 3rd and 4th numbers.
Kris Rachford
C/S 3032
