Old 02-21-2012, 06:14 PM   #1
HEADSUP113
Default Restrictor plates
Any input ? Sbc, flat top piston, 10/1 550 hp, 750 hp carb 1 power valve, vic jr, runs 11.0o.we have run this combination for 5 years with out issue, we tryed using a restrictor plate to race index and the one time we did it worked however after the 5th pass we lost a head gasket and after the tear down found # 8 piston was missing a 1/2 x1/4 inch piece off the outer edge, no other damage. Most of the plate people ive talked to said it has nothing to do with the plate ! But its strange that it never happend before and its been 2 years since that happend, and we race almost every week. Dont want to lose a motor ? Any thoughts
HEADSUP113 is offline   Reply With Quote
Old 02-21-2012, 06:19 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Restrictor plates
I've been using a restrictor plate since 2008 to kill about 100HP of my 900+HP BBC while logging 250+ passes a season. Your issue has nothing to do with the plate.
Old 02-21-2012, 06:33 PM   #3
HEADSUP113
thanks ed i knew u would be the 1st to answer this ill call u for details (pat)
Old 02-21-2012, 06:46 PM   #4
1320racer
1320racer's Avatar
Barbone?
Old 02-21-2012, 09:37 PM   #5
HEADSUP113
Yes. Mikes car
Old 02-22-2012, 07:21 AM   #6
1320racer
1320racer's Avatar
Pat, you're aware of my setup, but for those following along that aren't, I'm posting this reply from another thread...
"when running a 4150 carb, there is no better than the adjustable restrictor plate manufactured by Willys and sold through Summit, Jegs and others.
Been using this plate since 2008. Previously to slow my 9 second Chevelle to 10.0 and since 2009 to slow my 8 second Firebird to 9.0 enabling me to run 9.0x all season long at every track I compete.
This 1" 4 hole plate has 18 turns of adjustment in it from fully open 1.75" bore(s) to 1.00"
Each turn is worth ~.04 and can easily kill 100HP.
Nothing to take apart or swap out, couldn't be easier or simplier. Adjustment(s) take a few seconds and are infinitely adjustable.
Several competitiors and friends are now using it on their 8 to 11 second rides to slow them to make ET cutoffs and/or index classes as well I know of 1 former Division 1 Super Street Champion now using it after hearing about and seeing it in use on my car."
Old 07-03-2012, 01:36 PM   #7
wally54
Hey Ed......
After reading this thread I purchased this product wow does it work nice and nobody is the wiser...Now with that said have you ever had a problem with it closing up after you set it on it's own. The only thing I have done is put a rubber plug on the screw to make it look like a vacuum plug.
Thanks Glenn..
wally54 is offline   Reply With Quote
Old 07-04-2012, 11:37 PM   #8
1320racer
1320racer's Avatar
Glenn, yes when I first started using in 2008. The fix is a drop or two of Loctite on the screw, running it all the way in and out and it will now stay put.
Old 07-14-2012, 03:13 PM   #9
wally54
Thanks Ed ...I will give that a try..
Old 08-16-2019, 04:41 PM   #10
Wilson1
I run a 1050 4500 at altitude and want to slow it down from 8.4 to 9.0 so I can run Pro. I am going to build my own plate. Does anyone have any idea where I should start for hole size. The carb is 2.25 inch now.. I was thinking about 1.75 or 1.68??? Anyone??
Wilson1 is offline   Reply With Quote
