question: what causes a carb to smoke after the engine has been turned off?
always thought to change metering block gaskets, but they are new...
Keith you maybe leaking gas through the needle and seat. I'd check that first it don't take much if that's not it you may be a little rich on your setup. Hope this helps.
Liked 21 Times in 9 Posts
Gotta agree with fuel getting past the needle andseat assembly. I don't
beleive that it is a issue to worry about. |
thanks guys, any way to check this, or a remedy, or just replace needle and seat?
Liked 10 Times in 7 Posts
Also check the gaskets behind the power valve/blocks
Rick
Rick Bailey 3439 SC |
Keith just change the needle assembly and see what it does
So ??????
Make sure the Float is set properly
Make sure the Needle & Seat are in good / usable condition Make sure the Seat Is Tight (yes, I have seen these loosen & start to back themselves out) Verify Proper Fuel Pressure
Larry Fulton |
Liked 7 Times in 5 Posts
Is it really smoke?? Could it be fuel vapor coming back up from an open intake valve?
most of the time its fuel vapor. left over gas in intake. if anything is leaking look down carb with flashlight you should see boosters dripping if seats/floats are leaking
