Old 03-07-2012, 03:31 PM   #1
Keith 944
Keith 944's Avatar
Default carb ?
question: what causes a carb to smoke after the engine has been turned off?
always thought to change metering block gaskets, but they are new...
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-07-2012, 04:22 PM   #2
HR9121
HR9121's Avatar
Default Re: carb ?
Keith you maybe leaking gas through the needle and seat. I'd check that first it don't take much if that's not it you may be a little rich on your setup. Hope this helps.
James Williamson
W200 J/SA. SS/JA
Old 03-07-2012, 07:51 PM   #3
jims5600
Liked 21 Times in 9 Posts
Default Re: carb ?
Gotta agree with fuel getting past the needle andseat assembly. I don't
beleive that it is a issue to worry about.
jims5600 is offline   Reply With Quote
Old 03-08-2012, 10:15 AM   #4
Keith 944
Keith 944's Avatar
Default Re: carb ?
thanks guys, any way to check this, or a remedy, or just replace needle and seat?
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-08-2012, 01:06 PM   #5
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Default Re: carb ?
Also check the gaskets behind the power valve/blocks
Rick
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 03-08-2012, 03:17 PM   #6
jims5600
Default Re: carb ?
Keith just change the needle assembly and see what it does
Old 03-09-2012, 10:03 PM   #7
Rick Bailey
Default Re: carb ?
So ??????
Rick Bailey 3439 SC
Old 03-11-2012, 04:36 PM   #8
Larry Fulton
Larry Fulton's Avatar
Default Re: carb ?
Make sure the Float is set properly
Make sure the Needle & Seat are in good / usable condition
Make sure the Seat Is Tight
(yes, I have seen these loosen & start to back themselves out)
Verify Proper Fuel Pressure
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 03-12-2012, 12:09 AM   #9
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Default Re: carb ?
Is it really smoke?? Could it be fuel vapor coming back up from an open intake valve?
reknapp52 is offline   Reply With Quote
Old 03-12-2012, 08:48 AM   #10
440lebaron
Default Re: carb ?
most of the time its fuel vapor. left over gas in intake. if anything is leaking look down carb with flashlight you should see boosters dripping if seats/floats are leaking
440lebaron is offline   Reply With Quote
