Hello all, Perhaps someone knows of or has expierenced this. I set the MSD crank trigger to 35 degrees but when I check it with a timing light it is only at 32 degrees. I checked to make sure that the damper it true @ TDC and it is. So is there a, + or - in the MSD box? I wouldn't think so. Any ideas?
Thanks, Kevin T |
#2 | |
Chris Williams 6304 SC, TD, ET |
Liked 888 Times in 239 Posts
Also be sure to use a non adjustable timing light to set timing with an MSD.
Multiple strikes play hell with the adjustable advance electronics on the adjustable lights.
Forgot to mention, it is a 7AL3 box.
kt |
MULTI-STEP RETARD
There are four retard modules available with the 7AL-3. Each module is activated independently by removing ground from the corresponding module. The controlling terminals are listed as RET-1 through RET-4 and are located on the third terminal strip. The modules can be activated in any order and are cumulative unless deactivated. The maximum amount of retard allowed is a total of 20° even if the modules add up to more than 20°. Note: If a Retard function is not going to be used the corresponding terminals must be grounded, or a "zero" degree module must be installed. |
I know that, all the retards have zero chips in.
kt |
The chips are sometimes bad. I have the chips in, and have a jumper grounding all four of the screws on the front for the retard triggers. More than one guy has been burned by one of the chips not being enough.
Chris and Pat, thanks for the advice, will tie the chips together and gound them. I'll check the timing again. Will let you know if that works.
Kevin |
