Old 04-14-2012, 12:25 PM   #1
KEVIN T
Default Timing?
Hello all, Perhaps someone knows of or has expierenced this. I set the MSD crank trigger to 35 degrees but when I check it with a timing light it is only at 32 degrees. I checked to make sure that the damper it true @ TDC and it is. So is there a, + or - in the MSD box? I wouldn't think so. Any ideas?
Thanks,
Kevin T
KEVIN T is offline   Reply With Quote
Old 04-14-2012, 06:18 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: Timing?
Thanks,
Kevin T
What box? The 7AL3 differs from the 6 and even the 7AL2 by a few (2-3) degrees. Known issue, that everyone just gets used to. Go by the timing light.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 04-14-2012, 07:07 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Timing?
Also be sure to use a non adjustable timing light to set timing with an MSD.
Multiple strikes play hell with the adjustable advance electronics on the adjustable lights.
Old 04-15-2012, 01:12 AM   #4
KEVIN T
Default Re: Timing?
Forgot to mention, it is a 7AL3 box.
kt
Old 04-15-2012, 09:40 AM   #5
powerstrokeace
Default Re: Timing?
kt
On this box you MUST put in the ZERO chips in the front of it. If you don't all kinds of weird thing happen. It states this in the MSD book
Ace
powerstrokeace is offline   Reply With Quote
Old 04-15-2012, 11:22 AM   #6
powerstrokeace
Default Re: Timing?
MULTI-STEP RETARD
There are four retard modules available with the 7AL-3. Each module is activated independently by removing ground from the corresponding module. The controlling terminals are listed as RET-1 through RET-4 and are located on the third terminal strip. The modules can be activated in any order and are cumulative unless deactivated. The maximum amount of retard allowed is a total of 20° even if the modules add up to more than 20°.
Note: If a Retard function is not going to be used the corresponding terminals must be grounded, or a "zero" degree module must be installed.
Old 04-15-2012, 02:43 PM   #7
KEVIN T
Default Re: Timing?
I know that, all the retards have zero chips in.
kt
Old 04-16-2012, 09:49 PM   #8
Chris Williams
Default Re: Timing?
kt
The chips are sometimes bad. I have the chips in, and have a jumper grounding all four of the screws on the front for the retard triggers. More than one guy has been burned by one of the chips not being enough.
Old 04-17-2012, 09:13 AM   #9
KEVIN T
Default Re: Timing?
Chris and Pat, thanks for the advice, will tie the chips together and gound them. I'll check the timing again. Will let you know if that works.
Kevin
