Old 04-26-2012, 12:12 AM   #21
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: 502 Ram-Jet Crate Engine Bracket Racer ?
No, it's a $6,000 trans TODAY, nearly 3 1/2 years since his post!
http://www.coanracing.com/Catalog.as...uctDetail=1355
not to mention the required $430 shifter!
Your misinformation stands as such!
Old 04-26-2012, 12:16 AM   #22
HP HUNTER
Liked 373 Times in 129 Posts
Well Ed, since your on a roll here why dont you put up the 11,000 and lets see if my oval port big block makes 800 HP, could be 11,000 for you for a simple dyno test, step up.
Old 04-26-2012, 12:20 AM   #23
1320racer
1320racer's Avatar
sure, go ahead and build it, send it to me and I'll wave my typical fee for testing manufacturers/builders parts and install it in a typical footbrake launched, small tire bracket car that won't be backed up by a $6k trans , The ET slip is the final arbitor NOT a dyno!
Old 04-26-2012, 12:25 AM   #24
HP HUNTER
sure, go ahead and build it, send it to me and I'll wave my typical fee for testing manufacturers/builders parts.
That what I thought............
Old 04-26-2012, 12:28 AM   #25
1320racer
1320racer's Avatar
ain't interested in helping you build your business through lies, deception and misinformation while seeking out the clueless and naive.
Old 04-26-2012, 12:31 AM   #26
HP HUNTER
I wouldnt rely on your expertise to make my engine look good after seeing what your came up with in 20 years of racing your 68 at "Disneyland"
Old 04-26-2012, 12:38 AM   #27
1320racer
1320racer's Avatar
20 years ago my 4000+lb. streetcar/show car Chevelle with the stock 396/350HP under the hood was running mid 12's with a Q-Jet and through a full exhaust system.
16 years later and the year it was sold, the same all steel show quality car, now tipping the scales at 3880 lbs., still with power steering, power brakes, tilt wheel, full factory interior and a full exhaust under it ran well in the 9's with a restrictor plated 522 under the hood as well 137 MPH, wasn't backed by a $6,000 trans nor run in -500 feet air either and the pump gas, cast iron oval port headed 468 that was under the from '95 to 2007 ran a best 1.28 60 foot and 10.07 @ 131, 5 years ago in 2007 as well it was quicker and faster than every 468, 496, 502, most 540s and GM's 720HP 572 in similar weight, small tire Chevelles competing in Division 1 brackets.
Old 04-26-2012, 12:56 AM   #28
HP HUNTER
16 years later and the year it was sold, the same all steel show quality car, now tipping the scales at 3880 lbs., still with power steering, power brakes, tilt wheel, full factory interior and a full exhaust under it ran well in the 9's with a restrictor plated 522 under the hood as well 137 MPH and wasn't backed by a $6,000 trans nor run in -500 feet air either.
9.89 @ Disneyland, with a aftermarket 522 @ 134 LOL in negative 1800 air, 30.4 baro, LOL LOL AW.
Old 04-26-2012, 01:00 AM   #29
1320racer
1320racer's Avatar
still trying to peddle that lie?
Old 04-26-2012, 01:02 AM   #30
HP HUNTER
1.28 60, still trying to peddle that lie, post the time slip, but you cant, can you.
