Old 04-25-2012, 12:06 PM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question Braille battery....any users want to comment
Just curious......any users want to comment......which model for a stocker---is there a special charger----can you use them together in pairs-----any negatives ????
Rusty Davenport is offline   Reply With Quote
Old 04-25-2012, 12:13 PM   #2
FED 387
Liked 335 Times in 182 Posts
Exclamation Re: Braille battery....any users want to comment
First Braille batteries are made by DEKA check out the DEKA powersports line same battery---- second Brailles cost about almost 50% more than the exact same Deka battery---third Braille exagerates the CCA specs on the battery compared to what DEKA claims it to be--- yes you can use them in pairs or triples---- No you do not need a special charger other than using the correct charging amperage and a charger that is designed to be used with AGM batteries---
Old 04-25-2012, 12:55 PM   #3
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Braille battery....any users want to comment
I used an 11 lb Braille bat in my R/SA Jeep 6 cyl for 3 years BUT- it is not enough to go rounds - 1 run every hour with charging is what you get.
Switched to Deka 18 lb last year and requires less charging and always starts - also costs about $80 instead of $150!
Rsmith38 is offline   Reply With Quote
Old 04-25-2012, 01:28 PM   #4
Rusty Davenport
what Deka battery are you using...will it go rounds??? ( of course that question is not for me just sounds good )
Old 04-25-2012, 03:28 PM   #5
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I bought one earlier the year, p/n 3121. Works for me. You need to use one of the low amp/mantainer chargers. I don't have an electric water pump(pure stocker), so all it does is start the car. I've made 8 runs at a test&tune, no problems. If I knew about the Deka, I'm sure I'd would have gone the route.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-25-2012, 03:30 PM   #6
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
OK, let's get the facts straight here.
Deka and Braille are NOT the same battery. Not even close.
The only thing they have in common is that both are manufactured in Pennsylvania by East Penn Manufacturing. That's it.
Deka batteries are made to Deka specs and Braille to their specs.
Braille specs are not over stated and they have the best racing battery warrantee in the industry.
If you buy too small a battery for your needs it will not perform to expectaions.
We are a dealer and a firm believer in the product.
Tony and Beth's EFI stockers both have had the B3121 Braille batteries in them for 5 years now.
I think their performance record speaks for itself.
If you are interested in one feel free to call me at 219-861-1214 days.
We stock the B3121
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 04-25-2012, 03:43 PM   #7
brett3533
brett3533's Avatar
Liked 56 Times in 17 Posts
Are any of you using a alternater with the braille light battery or is it ok to use the alternater to keep it up .
Brett McFarland
A/S
brett3533 is offline   Reply With Quote
Old 04-25-2012, 03:48 PM   #8
Alex Denysenko
Functioning 65 amp alternator in both stockers Brett.
Old 04-28-2012, 11:00 AM   #9
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Was going to ask the same question!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 05-01-2012, 02:05 PM   #10
Jim Kaekel
Liked 536 Times in 110 Posts
I've run them for just over three years and they've worked very well for me. I use the B3121, one up front and one in the trunk.
Jim Kaekel 3836 STK
