Old 05-28-2012, 02:02 PM   #1
Elan Imseis
Elan Imseis's Avatar
Default under carb throttle stop
Hey all, not really familiar with the technology around how these work, but was wondering which under carb throttle stop you would recommend for someone that didn't want to use air or electronic operated units....ie manually adjustable.
Any thoughts?
Elan Imseis
Ontario Street Car Association - 11.90 Index and Open Comp Racer
68 Camaro - 11.37 @ 120 mph
Elan Imseis is offline   Reply With Quote
Old 05-29-2012, 02:35 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: under carb throttle stop
There is usually a plate system listed in the National Dragster vendor section. It is more like a restrictor plate, but you dont have to remove the carb. The under carb spacer has a slot to access the restrictor plates.
Is that anything like what you are thinking, or are you thinking by a cable?
Old 05-29-2012, 03:57 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Old 05-30-2012, 06:03 PM   #4
Elan Imseis
Definitely under car, and I've heard of spacers that double as adjustable restrictor plates - has anyone used this type? Is like to hear pros and cons or your experience with them.
Thanks....
Elan Imseis
