Old 06-08-2012, 12:25 PM   #11
drgrcr1156
Liked 2 Times in 1 Post
Default Re: Fuel Pump Recommendation
Originally Posted by DIAPERMAN View Post
Reliable and service Great company.Also they are all racers at the track all the time
Did have a very informative conversation with Aeromotive. Unfortunately, the space I had available was limited and was geared around the BG pump and filter. I would not be able to make the Areomotive pump and filter fit so I had to opt for the Magnafuel pump and filter set up which fit with a small amount of additional fabrication and fuel line.
Bob
drgrcr1156 is offline   Reply With Quote
Old 06-08-2012, 08:06 PM   #12
68camaroSS
what is the noise level like on the Product Engineering 7 vane pump, compared to the megnafuel 500 pump?
68camaroSS is offline   Reply With Quote
Old 06-09-2012, 11:26 AM   #13
Chris Williams
Chris Williams's Avatar
Not familiar with the magnafuel, but I have used the PE pumps and they are great. Noise is not significant. Nothing like the Weldon, which are crazy loud (but well worth it in our EFI application, IMHO).
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 06-10-2012, 07:46 PM   #14
sc1153
sc1153's Avatar
Send a message via AIM to sc1153
you all are out of your mind .... WELDON is the way to go....
The Weldon pump has HUGE advantages over the competitors
1) They pay Contingency (national & divisional)
2) They have a LIFETIME GUARANTEE on the pump and parts
3) The pumps that we run on our race cars are the same pumps that the US Millitary use for the hydraulic systems on the Drones that fly over our war zones. (they can NOT fail there)
4) The prices for their pump is competitive with every other pump manufacturer.
So why else would you choose ANYTHING ELSE?
For me WELDON for life
Chris DePascale
S/ST 1531 & S/C 1153....Addicted Racing
Jad153@aol.com
sc1153 is offline   Reply With Quote
Old 06-11-2012, 09:53 PM   #15
Carl Juliano
Carl Juliano's Avatar
Liked 64 Times in 25 Posts
X2 on the Weldon, really nice piece, got one on the TS car.
Carl Juliano TS 1275
John Juliano SG 151
Carl Sr.
Carl Juliano is offline   Reply With Quote
Old 08-30-2012, 05:16 PM   #16
jim hensley
Anyone have an issue with fuel pressure going to 0 on launch? Had no issues using A2000 Aeromotive pump, and using same setup, bought a megnafuel quickstar300 pump/filter combo cause I liked their filter setup. About 3 tenths off the transbrake, rackpak shows fuel pressure spikes down to zero, right back up, then right back to zero then back up, then fine the rest of the run. Same results when checked pressure on both high side and low side location. Sent in fuel pump and regulator to megnafuel, said everything checked out fine, but did put new o-rings in the pump. Reinstalled and had same problem. Put my Aeromotive pump back on with no issues. megnafuel said they had no idea why this would happen. After further investigation, I was told by another major pump manufacturer to stay away from the pump/filter combo's with the vertical filter's as they can cause this. At least it was a problem in my case..
jim hensley is offline   Reply With Quote
Old 04-10-2013, 06:21 AM   #17
bricki
Howdy classracers HELP
I have a A 1000 pump feeding 750 hp located in the trunk doorcar 1.21 sixty foot - 10 to regulator on firewall - 8 return to tank in trunk.
Fuel pressure is set at 6.5 pounds, from half track to 1320 needle on guage jumps between 6.5 and 5 pounds does anyone have an idea whats going on what are your thoughts guys.
bricki is offline   Reply With Quote
Old 04-15-2013, 05:32 AM   #18
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
If the gauge is liquid(glycerin) filled, swapped it out for a non liquid filled gauge.
Old 04-17-2013, 11:17 AM   #19
Fowler Racing
Fowler Racing's Avatar
Liked 2 Times in 2 Posts
I replaced my BG500 with Weldon and won IHRA Div 1 Hot Rod Championship the same year. Weldon makes a great product.
Fowler Racing is offline   Reply With Quote
Old 04-17-2013, 12:47 PM   #20
FED 387
Liked 334 Times in 181 Posts
Bricki--- probably that fuel line is too small and you might have a lot of bends in it which will either cause restriction or aeration of the fuel---- remember pressure is one thing volume is another---- try to take the pressure closest to the carb---also when setting the pressure with an Aeromotive remember that the engine MUST be running you cannot do it correctly with the engine OFF!!!! I don't think you need a return line with that low of a HP engine either.
