Old 05-10-2012, 10:25 PM   #71
Hemi Moose
Liked 12 Times in 12 Posts
Default Re: Old Race Parts and Pieces
Originally Posted by James L Miller View Post
Would that be called A MAXIMUM Maximum Wedge, or an ULTIMATE Maximum Wedge? Maybe if two 4bbl carbs is good, then four ought to be killer? They probably couldn't get that much air flow into the cylinders anyway.
Actually I think it might of worked if they ran the 13.5:1 or higher compression and had longer intake runners on the Max-Wedge intake...running four 500 cfm carbs = 2000 cfm...running four 750 cfm carbs = 3000 cfm, and maybe bore & stroke it...If you think about it wouldn't be that much more different that a big cube Pro-Stock motor with two big dominators on top of a tunnel-ram.
Old 06-02-2012, 07:01 PM   #72
Hemi Moose
Christmas at Nichels Engineering. Maybe it wasn't Christmas, but sure looks like it.
Found another old shot from the K&K Insurance team...check out the motor mounts.
Old 06-23-2012, 10:23 AM   #73
IvanP
421 Super Duty Pontiac exhaust manifold. I took this at the 50th Anniversary race at Indy.
Does anyone know how many of these exotic manifolds were made?
IvanP is offline   Reply With Quote
Old 06-23-2012, 07:33 PM   #74
New challenge:
Old 06-23-2012, 10:25 PM   #75
Liteweight
Liteweight's Avatar
Liked 31 Times in 19 Posts
Ardun ?
liteweight
Old 06-24-2012, 07:51 AM   #76
You clicked on the picture, didn't you?
Old 06-24-2012, 09:43 AM   #77
James L Miller
Liked 25 Times in 16 Posts
I think the spark plug tube spacing makes it obvious. I don't know of another head that the plugs are paired like that. The newer Chrysler Hemi heads like the PS and PST heads have the center cylinders paired together and the ends spread apart.
Mopar 2 Ya!
Old 06-24-2012, 05:24 PM   #78
Liteweight
Liteweight's Avatar
Nope. It was a quess. Looked at the tube spacing & valve cover attatchment. Couldn't have been any production Hemi
liteweight
Old 06-24-2012, 07:25 PM   #79
Next:
Old 06-25-2012, 12:47 PM   #80
Ardun ?
liteweight
Just kiddin'. Hemi pros would fugure that one quickly.
Now, scratch your head on the newest pic I found.
