Old 05-21-2012, 09:06 PM   #1
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Default Loose booster in dominator
I have a 1050 dominator with a loose booster. It falls right out if you tip the carb upside down. What is the best way to repair this? It doesn't look damaged. Thanks in advance.
Dave
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 05-21-2012, 09:39 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Loose booster in dominator
small pin punch and "gently stake it " into position
Old 05-21-2012, 10:07 PM   #3
pmrphil
Liked 396 Times in 153 Posts
there should be a brass tube inserted into the booster through the body of the carb - if it's loose or missing they are easily replaced.
Phil Molski
PMR Performance
S/C 1623
Old 05-22-2012, 04:56 PM   #4
Dave Jung
Dave Jung's Avatar
thanks for the responses guys. Quick update, I dissassembled the carb and there was no tube through the main body holding the booster in place on any of them. I then took a small auto center punch and carefully punched a series of them in the booster and the carb body where it presses in. I then tapped the booster in place and it is good as new.
Dave
6535 stk
81 Malibu K/SA
Old 06-21-2012, 08:04 AM   #5
jmarkaudio
They need to have booster pins/ booster stake tubes in them. You can get them from BLP, ask for the .160 ID pins, they are not expensive. I use a 1/4 brass punch to drive them in. You really need them, they set the passage diameter to the booster. It will run without them, but not as well.
jmarkaudio is offline   Reply With Quote
Old 06-21-2012, 10:23 AM   #6
Dave Jung
Dave Jung's Avatar
Thanks for responding. Why would they be missing? Would someone take them out or do they not come from the factory with them? Who is BLP?
6535 stk
81 Malibu K/SA
Old 06-21-2012, 11:35 AM   #7
Phillip marvetz
Phillip marvetz's Avatar
Cool Re: Loose booster in dominator
You can't run that carb on the stocker Dave
2009 V/SA Record Holder
Old 07-11-2012, 10:11 PM   #8
jmarkaudio
Not sure why it came out, most you have to use significant force to pull out. I have seen one run without the booster pin, not a good thing to do though. I converted a carb to E85 for someone, and when we took the borrowed carb off and turned it over to drain the fuel the booster came out...
BLP.
http://blp.com/cart/index.php?main_p...roducts_id=372
