Old 07-24-2012, 01:37 PM   #1
Ron Brindisi Jr.
Default Proper wireing for alternator
Ok guys... have heard alot of different things... Some of the veteran's please chime in... Proper way to wire a one wire altenator, as well as 2 or 4 pole 'kill' switch and rating... Thanks!!!
Ron Brindisi Jr. is offline   Reply With Quote
Old 07-24-2012, 01:57 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Proper wireing for alternator
i always wired mine direct to the + terminal of battery, gets a full charge and does not affect the kill switch. now that being said, my ignition is wired to the other side of the switch, no chance of run on. works for me
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-24-2012, 10:04 PM   #3
Ron Brindisi Jr.
Thanks Keith! Ron
Old 07-25-2012, 12:44 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
I'd highly recomend including a 3" long ,12 ga. fusible link at each end of the alternator wire ,as it is always energized.
A pinched or rubbed thru wire without the fusible link or any way of disconnect, could spell disaster.
Old 07-25-2012, 05:04 PM   #5
jim hensley
X2. thats the way I did mine except I spliced in a 200 amp circuit breaker just before the battery.
jim hensley is offline   Reply With Quote
Old 07-25-2012, 05:16 PM   #6
Keith 944
Keith 944's Avatar
yes, forgot to mention, i did fuse that wire! good point.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 07-25-2012, 08:15 PM   #7
Ron Brindisi Jr.
Great Point guys... Thanks, I do not need a fire after 2 years on this project!
Did u guys use a 2 pole or 4 pole switch??
Old 07-25-2012, 08:26 PM   #8
Ron Brindisi Jr.
Top secret! lol
Old 07-25-2012, 08:56 PM   #9
jim hensley
2 pole.
Old 07-26-2012, 10:33 AM   #10
Keith 944
Keith 944's Avatar
2 pole, use a good switch, the amps they are rated for can differ. i used a flaming river. also, (my opinion) i liked the push off rod instead of just a switch hanging out the back.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
