What are guys doing to your setup to do double enter when the other class doesn't allow throttle stops? How are you satisfying tech and or the other racers?
Thanks. |
Call me stupid, but I don't understand the question !
Chuck Westcott- S/C -S/G 225 |
Liked 3,227 Times in 981 Posts
Think Straightliner is wondering about when racers double enter S/Pro and Pro or how many tracks are running 6.0, 7.0 etc (1/8 mi) and S/ST, S/G at the same event and certain classes dont allow electronics. I know some racers have easy boxes to take out for this reason or coil/stow wiring bundles to their boxes/throttle stops. Personally I wouldn't like to run an opponent who simply "unhooked" his electronics but there are tracks that allow it.
Yes I mean 10.90 with throttle stop and Super Pro with delay box but throttle stop is not allowed. I guess it's really not feasible, so I imagine you only double enter when Super Pro also allows throttle stops. I still wanted to pose the question in case someone has a trick setup!
Thanks |
If I understand correctly, you do the same thing I do. When I run SP, I just remove the TS wire from my 450 delay box. When I run SG, I just put it back. No other changes are required, takes less than 20 seconds.
