Old 02-16-2013, 11:03 AM   #21
Rory Christianson
Liked 9 Times in 6 Posts
Default Re: 58 Corvette RACEtoration is back online!
Very nice build Wade, looks great
Rory Christianson is offline   Reply With Quote
Old 03-04-2013, 05:02 PM   #22
L79racer
L79racer's Avatar
Any updates???
L79racer is offline   Reply With Quote
Old 03-04-2013, 10:59 PM   #23
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
I have a few more "one off things" ...very cool...but very labor intensive for sure....will be next week before I get any more pics up
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 03-20-2013, 06:56 PM   #24
Wade Mahaffey
Had the Corvette frame on the lift today, so I got a few shots of the rear suspension detail.
This is my modified Caltrack set-up. I am going with the leaf spring because of the amount of street driving I'll be doing. The race four link and ladder bar suspensions don't like torsional movement.
Trans cooler detail is between the main frame rail and the "X" brace
Trans mount detail and removeable "X" brace portion needed drop the trans
Old 03-20-2013, 07:24 PM   #25
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
That's nice work and well thought out.
Job well done.
Old 04-14-2013, 03:54 PM   #26
L79racer
L79racer's Avatar
TTT, Its that time again!! Time for an update.
Old 04-15-2013, 02:03 AM   #27
Rory McNeil
Wade, nice work, but are you sure there is enough room for the CalTrac front bracket to rotate before it contacts the frame? It looks pretty tight in the photo.
NHRA 6390 STK
M/S 85 Mustang
Old 04-15-2013, 07:58 AM   #28
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I think the car is on the lift and the rear is hanging down. That puts the brackets in a place they will not be once the car is sitting on the springs.
Wade doesn't usually miss much on his work.....
Rich Biebel
S/C 1479
Stock 147R
Old 04-15-2013, 07:29 PM   #29
Wade Mahaffey
Rich, you are correct. The spring arc will be allmost straight at static position. That will pull the CT bracket reward gaining clearence in the front. But it's nice to know that some folks on here actually look at the stuff. I think I have it covered LOL, but I never say never. I have some other stuff to share, but I have sent it to NHRA for compliance verification. Hope I did'nt make a mistake by asking for permission instead of begging for forgiveness like alot of other folks do. The last time I did this they changed the wording in the rule book....not for me, but because I pointed out how many (not who)were in violation of a current rule in the book. Now the new wording brings those in question into compliance....
Wade Mahaffey
Old 08-31-2013, 01:26 AM   #30
Wade Mahaffey
Red face Re: 58 Corvette RACEtoration is back online!
Well, I know I'm not settin the world on fire, but I am making a little headway on the car. I put the body on the frame the other day to check fit and function. While it's on the frame I will do several things that need to be done with the body in place.
This is the first time the car has been on the chassis since it was separated a few years ago. It has stock front suspension where a straight axle suspension once was. And now a 9 inch ford rear where an Olds rear was. I'm happy with the project and I know it's happy LOL
The shifter mounted on the trans is cool. It will allow faster converter changes during testing with quick disconnect fluid lines. The hole in the tunnel is large enough to allow the trans to move reward and then straight down....quick change the converter then back up in place. If you need to change out the trans, you can move the shifter over while the trans is on the bench where it's nice and easy. When I switch over to manual transmission, I don't have to deal with the shifter mounted to the floor. I want to have the stick and street engine able to swap out for the race application 283/glide. I'll be fabricating a two piece cover for the hole
Wade Mahaffey
