Old 08-21-2012, 08:27 AM   #11
THE LEGEND
Default Re: Vacuum pump help
Coot,
Have you thought about installing a pcv valve on both sides. We were doing that with Stocker motors a few years ago.
THE LEGEND is offline   Reply With Quote
Old 04-10-2013, 09:51 AM   #12
nhra686
nhra686's Avatar
We run regular seals and pull 12-15" of vacuum with no problem.
Bill Huntington
S/C, S/G, T/D, S/Pro
nhra686 is offline   Reply With Quote
Old 04-11-2013, 10:28 PM   #13
voltdr
Liked 100 Times in 51 Posts
I run about 14.2" at the finish line. I run the crank seal in the normal direction. No leaks, no issues. As stated earlier, the vac pump will help cure most oil drips and oozings.
voltdr is offline   Reply With Quote
