Old 12-24-2012, 10:50 AM   #11
Liked 17,108 Times in 1,557 Posts
Default Re: My 67 Shelby updates
Hey Rock,
I'm going to stick with the old 428. I know, I know I said was going to go with new technology, but I want to stay in stock. Besides, I still get to drive the new stuff, Anthony's 3 Valve CJ and The Hawk and Cook CJ.
I was spoiled when I was driving Anthony’s CJ, I love the inside cut off switch.
Old 12-24-2012, 11:04 AM   #12
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Stock runs so early.....lol
CBS is offline   Reply With Quote
Old 03-08-2013, 10:06 AM   #13
I wanted to keep the back seat and the passenger seat stock, but NHRA had other ideas, so with that I decided to remove the back seat and completely remove the factory look of the seating.
When I was doing this project I kind of forgot about my build, so I did not take photos until half way through the project. The photo of the stock seat is not mine, looks to nice for my car anyway. I just wanted show what the stock seat looks like.
I used .040 aluminum along with a carpet material used for speaker boxes. I decided to fabricate, I could have bought a rear seat delete made out of fiberglass, but I would have had to cut it up to make it fit and they are very pricey.
The materials were less the $75 and it took about about a day to finish. I used cardboard to make a template and make the cut out for the tunnel. I used 3M adhesive to attach the material to the aluminum. I use four trim screws to attach the panels. I made it two pieces for easy removal and to make it fit. I would not have been able to fit it between the roll bar if it was one piece. The rear piece gives me access to the upper rear shock mounts, remove one trim screw and I get easy access.
The total weight savings for swapping out the factory seating was 60lbs.
All I have left is to clean up the factory panels and paint the roll bar. When test fitting the aluminum sheets it was hard not to hit the roll bar, lots of scratch's to fill.
ID:	16668   Click image for larger version
ID:	16669   Click image for larger version
Old 03-08-2013, 02:06 PM   #14
Damn Yankee
Ken I like it, looks like a clean install
Damn Yankee is offline   Reply With Quote
Old 03-08-2013, 08:21 PM   #15
Mike Gray
Mike Gray's Avatar
Liked 703 Times in 203 Posts
Ken, that looks nice!
I have a question about your Shelby - Are you using the factory piece between the trunk and the passenger compartment, it looks like you may have changed it to an aluminum panel?
I think it's required when using an aftermarket fuel tank in the trunk?
I haven't gotten to my interior yet but I wasn't sure if I should use the stock pieces or build one out of aluminum.
Old 03-08-2013, 11:05 PM   #16
Thanks Yankee, the carpet is what makes it look clean. The aluminum does not have to be perfect and I'm far from being a good fabricator.
Mike, The panel in the back is factory and I think NHRA would be ok with it as long as it does not open like the way it came from the factory. If its fasten, I think your good to go. With that said, I do have another barrier made out of aluminum. its more to the trunk side.
Old 04-23-2013, 08:20 PM   #17
joe176
joe176's Avatar
Liked 41 Times in 9 Posts
Looks good Ken !!!! Great idea with the build section for posting.....interesting stuff !!!
Joe Franco SS176
joe176 is offline   Reply With Quote
Old 04-23-2013, 08:46 PM   #18
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Good job Ken, I never realized that there was that much room in the back of my 67 Mustang. Looks real nice. Claude
Old 05-17-2013, 01:46 PM   #19
Here is my seat compliance update. I have installed a my "identical in appearance" seat. Now if only I could get my engine finished I could try out my new safety features.
ID:	19028   Click image for larger version
ID:	19029   Click image for larger version
Old 11-18-2013, 10:09 PM   #20
DrJRacing
Kenny,
Are you sure the inside power shut off lever is legal and/or safe?
It is possible to imagine a car part or body part (ie a bent shifter support or the driver's leg, respectively) blocking this lever following a severe crash. This, in turn, could interfere with an outside safety official from successfully shutting off the power (to your fuel pump). On a convenience level it sure looks useful!
Doug Jonak
2012 SCJ SS/AAA
5268
DrJRacing is offline   Reply With Quote
