Old 11-11-2013, 11:14 AM   #21
MICROMACHINE72
Default Re: Hi all! New Guy here, Low Buck Comp build, E/ED
Thanks guys, yes we are building a homemade header, with a thick port spacer plate to get the intake out farther so the primaries can have a little straight shot before being bent. I'm on the fence however if I should do two 3 into 1 with 2-3" collectors or 6 into 1 3-1/2 collector. The engines don't scavenge well so I would think the 6 into 1 may be the ticket unless we get some pulse reversion? Maybe build both and see what works better. I'll take it to a local speed shop chassis dyno so I can play with the carbs, they only charge $100 for 2-hrs play. And yes, the pistons are your typical TRW-Speed pro heavy weights, but I have removed a bunch off the pin bosses, and with the rods I'm using they will be coming out the hole about .100 so we will mill the heads down around the dome, bring the ring pack up a little. Like I said earlier, this is the first effort, if all goes well I have plans for a homemade solid roller set up and fab up a better intake. The goal is High 8.90's/.8.80's with the first effort.
MICROMACHINE72 is offline   Reply With Quote
Old 11-12-2013, 11:45 AM   #22
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
What design constraints will you be using to build your rocker arms?
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 11-12-2013, 01:14 PM   #23
MICROMACHINE72
I'm just using std. 1.7 BBC rocker arms
Old 11-12-2013, 01:43 PM   #24
Harry 6674
Very cool build. Maybe you'll get to pit on asphalt all the time or at least high and dry.
Harry 6674 is offline   Reply With Quote
Old 11-12-2013, 02:22 PM   #25
Marty Knox
Liked 44 Times in 19 Posts
I've been kicking around the idea of pairing cylinders, going 3 two into one, then three into one collecter.
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 11-13-2013, 03:33 AM   #26
cutta
cutta's Avatar
I gotcha, I though you may have been doing a clean sheet design of some. Was hoping to get some ideal stiffness, stress, and mass numbers.
Old 11-13-2013, 07:46 PM   #27
Marty Knox
This is an idea I got from Tom Langdon. Pair the 1 and 6, 2 and 5, and 3 and 4. The idea is to increase the mid-range torque.
Marty Knox 3071 STK
Old 11-13-2013, 10:24 PM   #28
RonTheAnnouncer
RonTheAnnouncer's Avatar
Way too much thought put into that. Just run zoomies!
Good luck on your build, Micro, I applaud your courage trying to run comp on a budget! I love looking at all of the wild engine combos guys run in that class.
Ron Huntley, Jr.
announcer and Half ed racer
"Those who can, do. Those who can't, criticize."
RonTheAnnouncer is offline   Reply With Quote
Old 12-07-2013, 06:50 PM   #29
MICROMACHINE72
Couple of new pics from last couple weeks up to today.. Need to get my ***** in gear if we are so make our goal to the gators.. Cutting the tops of the sleeves on the Bridgeport, Made a little fixture and final decked it today! Hurray! Might go out in the garage tonight and set up the final bore operation 4.00. Picked up this little Jewel (crank grinder) this past Thursday at an auction. I think I'm the only one in the neighborhood with one! 5.4 "stock" Triton-mod-motor rods ready to go!
ID:	22305   Click image for larger version
ID:	22306   Click image for larger version
Old 12-07-2013, 06:53 PM   #30
MICROMACHINE72
rods..
