Old 12-18-2013, 08:35 AM   #1
rickracer
Question EZ Plate Systems
Any Super Class racers use an EZ Plate System? Curious - would like to hear some input if you use it.
rickracer is offline   Reply With Quote
Old 12-18-2013, 01:11 PM   #2
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: EZ Plate Systems
Cannot imagine you are going to find many since it is a MPH game and the EZ plate system does just the opposite by killing MPH. Good system though I have a lot of freinds that use them in the Gas classes with great success.
sst7250 is offline   Reply With Quote
Old 12-18-2013, 02:38 PM   #3
Queball Lattie
I have used the E-Z Plate System for 2 years and love it.
Queball Lattie is offline   Reply With Quote
Old 12-18-2013, 08:47 PM   #4
voltdr
Liked 100 Times in 51 Posts
Which class and type of car?
Dan
voltdr is offline   Reply With Quote
Old 12-18-2013, 10:01 PM   #5
Queball Lattie
11.00 index, Super Street, and Hot Rod small block Vega.
Old 12-19-2013, 07:59 AM   #6
rickracer
What about the Willys Carb restrictor plate? That is adjustable without adding or removing plates.
Old 12-19-2013, 11:14 PM   #7
HR9121
HR9121's Avatar
I used a Willy's a few times when I was running some index races and it worked really well for me. Only problem I ever had was the threaded part started loosening and the vibration would cause it to open, someone told me about putting a little locktite on the threads and never had another issue. I did use it at a couple division races in hot rod and it was very dialable, my car was a slower car so the loss of mph was not an issue to me because I was used to looking over my shoulder 98% of the time anyway.
James Williamson
W200 J/SA. SS/JA
Old 12-20-2013, 02:17 PM   #8
sst7250
sst7250's Avatar
I think if you are simply trying to shave a little in ET then these systems are likely the best way to go.
Old 12-20-2013, 04:42 PM   #9
HR9121
HR9121's Avatar
Agree with this 100%, my car was a low hp car and would only be on the throttle stop around a half second and sometimes could be very unpredictable at times. I would say for racers only needing to slow down 3 or 4 tenths this would be the way to go otherwise go for the mph.
James Williamson
W200 J/SA. SS/JA
Old 01-02-2014, 04:02 PM   #10
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Been using Willy's adjustable restrictor plate for the past 6 seasons. That said, there is no simplier, easier or quicker way to adjust your ET up to 5+ tenths in less than 30 seconds.
