Old 01-19-2014, 09:39 PM   #131
farmco r/sa
Liked 147 Times in 54 Posts
Thumbs up Re: Project Junkyard Dog
Originally Posted by Joe Toller View Post
Thanks. The smell was a pain, and will always be there short of replacing everything, which defeated the purpose.
I decided not to build mine as a 75, for the AFHS reason, I figured that would be the one everyone builds. Hopefully mine gets left alone...
i hope so. hopefully you qualify top half and go rounds.
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
Old 01-19-2014, 09:54 PM   #132
Joe Toller
Liked 9 Times in 9 Posts
Default Re: Project Junkyard Dog
I appreciate that. I hope it qualifies at all lol!
Joe Toller
Lewistown, MT
Old 01-19-2014, 09:57 PM   #133
farmco r/sa
it should. keep the faith and ambition...
P/SA
Old 02-03-2014, 12:26 AM   #134
Joe Toller
A new item to share; if you convert a 75-77 Maverick or Comet to manual steering, make sure you get the proper center link. They are unique to those years only, the tie rod taper is different than 70-74. It cost me $38, but it's now right on. I also had a slightly tweaked left strut rod, so I grabbed one from the wrecking yard last week, before it hit below zero. As I sit I am a Blue Streak converter and a little cosmetic work away, and after totaling costs and deducting what I sold off the car, I am still under my $2014 budget, after converter and some rustoleum I will have just enough to drag it to the alignment shop...after that the real work begins!
Maybe I should have built a garage first?
Joe Toller
Lewistown, MT
Old 02-03-2014, 06:46 AM   #135
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
throw a bunch of dryer sheets in it and change 'em out every couple of weeks...
Old 02-03-2014, 09:23 AM   #136
Joe Toller
Oh I did, I even stripped the interior, shampooed it, and scrubbed the shell with water and bleach. The mouse piss just soaked in that bad
Joe Toller
Lewistown, MT
Old 02-03-2014, 09:44 AM   #137
Tom keedle
Tom keedle's Avatar
febreeze has worked well for me too.
haven't tried the unscented stuff yet...
Old 02-03-2014, 11:06 AM   #138
Doug Domm
Liked 84 Times in 21 Posts
A negative ion generator (ozonater) WILL do the trick. I have rescued several with them. Smells like an electrical storm has just passed over when done, rather fresh smelling. The mouse smell never returned even on the hottest days with windows closed. Some water treatment plants even use negative ions. It will neutralize bacteria. Hotels use them to turn smoking rooms into non smoking rooms. One word of caution is I've found some rubber trim items such as Hurst shifter boots tend to deteriorate from this. You may want to read up on negative ions first as my disclaimer.
Doug Domm is offline   Reply With Quote
Old 02-03-2014, 11:45 AM   #139
Joe Toller
Good to know in the future. The car is long gone now though. The Comet is clean as can be fortunately.
Joe Toller
Lewistown, MT
Old 02-03-2014, 07:37 PM   #140
Bench Racer
Liked 99 Times in 21 Posts
Try using a bag of new charcoal briquetts (not the matchlite stuff) in aluminum roasting pans along with several boxes of baking soda. Used this in an old camper that a mouse or too had used over the winter and it helped absorb a lot of the odor.
Bench Racer is offline   Reply With Quote
