Old 01-24-2014, 03:04 PM   #11
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Re: 1965 Malibu Wagon build
Mark, is the 200 metric now a acceptable replacement for a p/g in this combination? Just asking as it's been a while away from class racing....thanks.....
NORMAN BARNARD is offline   Reply With Quote
Old 01-24-2014, 03:08 PM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
TRANSMISSION, Automatic
Any model transmission, same make as car, with a maximum of
three forward speeds (unless OEM equipped with more than
three forward speeds). O.D. gear not required, reverse permitted.
Transmission case must be OEM or aftermarket OEM replica
from a standard, automotive application as found in the Official
NHRA Stock Car Classification Guide. Aftermarket case must
meet SFI Spec. 4.1 and 30.1. NHRA-accepted adapter plates
permitted. Modifications to shifting patterns are permitted,
provided full shift pattern is retained. Full shift pattern must
include park and reverse. Any gear change must occur as a
result of an internal function of the transmission or from direct
action by the driver. Lockup converter permitted if OEMequipped
with lockup converter and OEM transmission is used.
Otherwise, lockup converters prohibited. Electronic rpm controls
for the electric (internal or external to the transmission) shifting
of automatic transmissions permitted in computer-controlled
vehicles only. Otherwise, any gear change must occur as a
action by the driver. Pneumatic, hydraulic, electric, etc. controls
and shifters in all noncomputer-controlled electronic-fuelinjected
vehicles prohibited. Deepened stock or aftermarket
transmission oil pans permitted. Drilling of transmission case or
rear of engine block to adapt incompatible units prohibited.
Functional neutral safety switch mandatory. Transmission brake
prohibited. Tailshaft modifications for bushing replacement, or
NHRA-accepted aftermarket tailshaft, permitted. See General
Regulations 2:12, 2:14.
Rich Taylor
I/SA - 321
Old 01-24-2014, 05:43 PM   #13
farmco r/sa
Liked 147 Times in 54 Posts
Question Re: 1965 Malibu Wagon build
Originally Posted by HandOverFist View Post
Was this an ambulance? Body in the back of pic #2?
or a hurse?
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
Old 01-24-2014, 07:56 PM   #14
Freddie Cain
Freddie Cain's Avatar
Take Dwights advice and put a stick in it !
Freddie Cain is offline   Reply With Quote
Old 01-25-2014, 12:14 AM   #15
Charlie Berner
Charlie Berner's Avatar
Liked 8 Times in 2 Posts
Todays progress. Ready for sealer and paint. Saturday night it will be red..
I got the glide and converter. All ready. The 283 is almost ready. Not looking for low et and top speed with this car. This is the play car who ever come with me racing get to drive this one.
Charlie Berner is offline   Reply With Quote
Old 01-25-2014, 03:20 AM   #16
Bench Racer
Liked 99 Times in 21 Posts
Thumbs up Re: 1965 Malibu Wagon build
You gotta love a wagon!! You will have an eyecatcher there. Bill Reavis from N.C. ran one of these in IHRA Super Stock production back in the early 80's. He ran a 283 in the 2bbl production class as did my brother with a 58 yeoman 2 door wagon. The "hot ticket" then for 2bbl. production S/S was a 283+.060, 302 steel crank, aluminum rods, all the compression you could stuff in it, holley strip dominator, braswell 2bbl adapter, holley 650cfm 2 bbl., lunati RRA-271/281 roller cam, 292 turbo heads, crane rollers with a stud girdle, and RPM it like a chainsaw. Keep the pictures coming, I can't wait to see more. Don Jackson
Bench Racer is offline   Reply With Quote
Old 01-25-2014, 02:03 PM   #17
NORMAN BARNARD
Rich taylor, you have a pm.....norm
Old 01-25-2014, 06:45 PM   #18
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
have a great time painting tonite.
545 here on Long Island. 28 degrees, heavy snow fall for now to top off our frozen snow we got already.
Chris
looking forward to more pictures
chris ok is offline   Reply With Quote
Old 01-25-2014, 08:03 PM   #19
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Great project ...... more pictures please
Old 01-26-2014, 08:38 PM   #20
Charlie Berner
Paint is on. Dave put down a bitchin paint job in the middle blizzard in his backyard one stall garage that puts most high dollar shops work to shame.
ID:	22727   Click image for larger version
