Old 03-03-2014, 12:49 AM   #81
Geerhead55
Liked 5 Times in 5 Posts
Smile Re: '67 Camaro E/SA redo
Rich,, I'm glad you got it back together so quickly,,, but I do hope down the road that Moser is made aware of this, so that they can look into producing a better product in the future. Good luck with your car,, I hope you'll go to Columbus in May.
Danny Durham
Old 03-03-2014, 12:58 AM   #82
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Thanks Danny - I sent a email to Moser about the problem...we will see how they follow up. No concrete plans on where to run this year yet...kind of wait and see how the car runs first. Without any further breakage I should have an idea this coming Saturday.
Rich Taylor
I/SA - 321
Old 03-03-2014, 04:29 AM   #83
J&S Racing
Liked 327 Times in 87 Posts
Interesting, when I ordered my rear from moser I asked if they would install the Calvert perches. I was told absolutely not as they felt there's were much stronger. I wish I remembered my sales person cause I'd love to send him those pics.. Car looks good!!!!!
Old 03-03-2014, 07:33 AM   #84
brent flynn
brent flynn's Avatar
Glad you got it back together!! Im gonna look under my car... I have Caltracs, 2* wedges and no spacers... Mine has 100's of passes on it...they must have used better perches on mine...I had them put them on in 2001... Car has made several hundred passes in the 11.50 or faster range...After seeing your failure, it makes me want to have some bracing welded onto mine...
Old 03-03-2014, 07:36 AM   #85
HandOverFist
I feel like if we had a big block in the car Brent they would have failed in the water box. Ours failed from the very first pass evident from the mph on the time slip...the second launch just sealed the deal. Perry says he has seen this on many stick cars, but nothing this extreme.
Rich Taylor
I/SA - 321
Old 03-03-2014, 08:36 AM   #86
Rich Biebel
Rich Biebel's Avatar
Liked 549 Times in 215 Posts
Nice work.....old school...a heat wrench, and probably a hammer and pry bar. Add some metal and weld it up.....
Parts cost.....zero...
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 03-03-2014, 08:43 AM   #87
HandOverFist
Thanks Rich...not nearly as pretty as before haha! Beauty queen is out and we are going for function this time.
Rich Taylor
I/SA - 321
Old 03-03-2014, 03:48 PM   #88
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Originally Posted by HandOverFist View Post
Thanks guys - If we can make it run decently this spring I will treat it to a new paint job/interior come fall. The car was only able to muster a 7.39 with F weight when we got it...we will see what it can do with the new parts come spring.
Looks like the old rear end had the appropriate reinforcement. Oh well....that's racin'.
Dave Turner
SS/GT #1153
Old 03-03-2014, 04:02 PM   #89
Dave Turner
Speaking of parts wanted/needed - I'm looking for a extended fuel fitting, 1"x20 8AN for a Edelbrock carb like the one pictured below but have had no luck locating a source. Anyone have a link?
I think quadrajetparts.com has a 2 piece solution for you. A 1" extension plus an inverted flare to -8 adapter.
Dave Turner
SS/GT #1153
Old 03-03-2014, 04:12 PM   #90
HandOverFist
It did, but the perches on it were welded in the wrong place...had the housing skewed nearly an inch toward the drivers side. If I had it to do all over we would have just cut them off and welded some Caltrac perches on it in the correct spot. My partner was hell bent on a new housing tho...
Rich Taylor
I/SA - 321
