Old 03-09-2014, 04:44 PM   #1
L79racer
L79racer's Avatar
Default Mid year corvette cage ?
Getting a cage put in my 66 convertible. I would like to see some pictures of some cages. It is a stock chassis and stock seats. If anyone can post a few pictures it would be a great help. Thanks in advance.
Vinny
L79racer is offline   Reply With Quote
Old 03-09-2014, 04:58 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Mid year corvette cage ?
The pics on pages two and three might help. I'll add more to this post if I find them.
Caging A Corvette (from another forum)
Another from Corvette forums
Here's a 76 from YB This is a newer car, but the build is very detailed.
Dale
Dale Shearon
68 Mustang 6394
Old 03-09-2014, 05:40 PM   #3
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Vinny
I'll have to see if I have any pics laying around of the cages in our cars. To get the angle of the rear bars correct, you'll need to notch the rear deck. With tubs, there is no room to put in bars angled in from the main hoop to the center floor of the car. You might have more room with a stock chassis. A properly done 6 point cage in one of these cars will cert to 8.50.
I recommend speaking with Tom Goldman, who is on this board. He has crawled all around our cars over the years and knows what needs to be done to make it right.
Hope this helps.
Old 03-09-2014, 05:56 PM   #4
L79racer
L79racer's Avatar
Thanks for replying guys. I seen most of the cages on line as Dale posted. I installed a cage in my 80 with race seats. In the 80 I welded the main hoop down onto the rear cross member up against the inside of the kick up of the rear section of chassis. In the 66 with the stock seats there doesnt seem to be enough room. I was thinking of placing the main hoop onto the kick up but then the rear bars are further back which would mean making the notch in the rear deck much longer. I will just be using the hard top only so I wont have to worry about the soft top interfering. I'll talk it over with the guy whose going to install the cage for me.
Jeff I have a few pictures of your Vette but I cant see the main hoop set points.
Old 03-09-2014, 06:41 PM   #5
Jeff Jewell
The main hoop is welded to the frame, about even with the crossmember that goes across. My drivers seat is actually under the main hoop and the cross bar that the head rest and seat belts mount to bends back behind the seat. It's all a tight fit...
Old 03-09-2014, 06:58 PM   #6
L79racer
L79racer's Avatar
Jeff if you get a chance can you send me a picture of your main hoop and rear deck? Did you remove the lever and cables to pop the rear deck locks?
Old 03-10-2014, 08:32 PM   #7
vetteboy
Liked 2 Times in 2 Posts
Here are a couple of pictures of my car. I just got the car back from being painted. I didn't have to modify any interior parts other than the deck lid. The hard top fits but tight. If you are a tall or bigger guy put a swing out bar in it.
ID:	23044   Click image for larger version
ID:	23045   Click image for larger version
vetteboy is offline   Reply With Quote
Old 03-10-2014, 09:16 PM   #8
L79racer
L79racer's Avatar
Glad you posted. You sent me a couple of pictures of you vette before it was painted but I couldnt remember what site you were on. What did you weld the main hoop too. It looked like it went into the corner of the chassis where that triangle brace is from the side rail to the rear crossmember is. I like the fit of our cage. Its pretty much what Im looking for. If you have a few more picture please send them. What size hoosier slick are you running. I Have a 28x11.5 et street on mine now to see the fitment. Its on a 7" centerline with a 4 7/8 back space. It just about fits from chassis to quarter panel.
Old 03-10-2014, 11:07 PM   #9
vetteboy
The car was in black primer when I sent you those pictures. The car looks awesome now. I run 29.5 x 9 M/T slick on a M/T wheel 4.5 back spacing. I made my own perch/pads off the frame so that the cage could be welded on a flat surface. I had the guy doing my cage tell me where he want to connect to the frame and then I took the body off the frame and made my perches/pads. If you need any more pictures or have any more question send me a PM. Brett
ID:	23050   Click image for larger version
ID:	23051   Click image for larger version
Old 06-01-2014, 08:18 AM   #10
L79racer
L79racer's Avatar
Just wanted to update this post. I had the cage done by Joe at Thriftway-Auto. He is a member here also and I think his screen name is Badnova.
