Old 03-30-2014, 04:34 PM   #11
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Re: Wet plugs on one side....
I'd replace the ignition box and coil. especially if it is a MDS 6 anything.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 03-30-2014, 05:58 PM   #12
Todd Hoven
Guest
Posts: n/a
does it have a crank scraper? What side of the engine is it again?
Old 03-30-2014, 06:55 PM   #13
Bob Shaw
Liked 323 Times in 63 Posts
Todd is thinking what I am thinking. If the rings are not controlling the oil it will foul one side more than the other.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 03-31-2014, 01:16 AM   #14
Adger Smith
Liked 880 Times in 311 Posts
Bob, I was thinking similar about oil except in the intake fit. Angle wrong and the bottom open to the valley or the end pads holding it up when tightened down or some brute tightened all of one side before he did the other.
Adger Smith (Former SS)
Old 04-01-2014, 01:12 PM   #15
Jody Lang
Liked 92 Times in 29 Posts
Thanks guys!
He still hasn't found the problem yet.
He's trying a new intake gasket next.
This motor has ran before. He took intake off to do a cam swap. Had a vacuum leak at intake so replaced that. Now it idles but has the current problem.
Ignition is a 6 not sure which one.
Car was started and ran intially without the MSD ground hooked up. Hooked it back up and no difference.
Maybe with ground not hooked up it did something to the box?
Also this is the 1st time he's used this brand of intake gaskets.
Jody Lang is offline   Reply With Quote
Old 04-01-2014, 02:56 PM   #16
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
A good ground is often overlooked and will mess up anything electronic, but I can't see it affecting only one side of the engine.
Dale
Dale Shearon
68 Mustang 6394
