Old 04-07-2014, 07:24 PM   #2871
Daily Hemi Dart fix
Old 04-07-2014, 07:39 PM   #2872
Gator Raider:
Old 04-07-2014, 07:58 PM   #2873
HEMIDARTDAVE
Liked 4 Times in 3 Posts
WOW, more than one Daily Hemi Dart fix...keep 'em coming....I will not OD.
Old 04-07-2014, 10:24 PM   #2874
lionshead
is post #2871 the same car as scat pack /dodge of glenn warfel ??
lionshead is offline   Reply With Quote
Old 04-07-2014, 11:06 PM   #2875
HEMIDARTDAVE
Yes
Old 04-07-2014, 11:14 PM   #2876
Old 04-07-2014, 11:23 PM   #2877
Last one for tonight :
Old 04-07-2014, 11:32 PM   #2878
Well...ok.
Back around post 1152 it was stated that this was the Johnny Rivers Dart.
Also stated it was rolled on the street and later rebodied.
Just reporting what was posted, not stating as fact.
Old 04-08-2014, 02:29 AM   #2879
mike s
Charlie, any info that the Hemi Dart ended up in the Detroit area?
mike s is offline   Reply With Quote
Old 04-08-2014, 09:37 AM   #2880
Liteweight
Liteweight's Avatar
Liked 31 Times in 19 Posts
Originally Posted by beekool View Post
hey daryl, what did your car run?
I made a few fun passes back in 08? with it.
At that time it had a VERY MILD street hemi that I built for my cuda, complete with pump gas friendly 10.25 compression, & a .509" flat tappet hydraulic camshaft. Fiqured I'd bolt the Xram on top & drop it into the Dart for a couple seasons while I was building the "real" motor. I was expecting it to be pretty much of a turd to drive with the Xram etc, but with a 5200 9" converter, 4.56's, & some rejetting it wasn't all that bad on the street,----soooo...... I fiqured let's throw it on the track just for the hey of it.
With complete exhaust still attached, it ran 10.94,10.93, & a 10.90 @ 122,123mph. The slicks were total overkill. Motor didn't have enough power to make them work. I quess not bad times considering it had 3 bent valves.
Lesson learned!!!!! NEVER ASSUME when you buy a freshly machined motor from someone & even tho both deck surfaces are freshly refaced that they are the same height................... I measured only one side & did my piston valve clearance on that side............. It just happened to be the tall side........................ I found out after the fact
liteweight
