Old 04-12-2014, 08:16 PM   #71
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Default Re: Update E-F/SA Bird Build...
I waited till 8:00 figuring you updated us with the numbers by now.
fred goodwin is offline   Reply With Quote
Old 04-12-2014, 10:38 PM   #72
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I had good weather as well Brent but results went to hell for me...convertor is junk.
Rich Taylor
I/SA - 321
Old 04-13-2014, 09:33 AM   #73
brent flynn
brent flynn's Avatar
Well, folks... had some problems yesterday... floated valves just before the 1/8...shifted at 5700, and track wasnt hooking...i believe i was loosing atleast .04-.05 in 60ft...car was real soft on launch...i felt the spin, but it was a gradual dig, all the way through low gear... So , i may have tagged a valve, not major damage. Will leak it tomorrow, and go from there. Will have new cam ground and go to limited travel lifters, if i find out that this is the problem. Im hoping i sucked dirt into the carb, after i did all the new fuel system work...
Name:	first stocker pass  float valves.jpg
Old 04-13-2014, 09:49 AM   #74
HandOverFist
Aint this fun Brent? I'm off to the shop in a few to pull the transmission...again. Sometime soon we will both have some good news to report.
Rich Taylor
I/SA - 321
Old 04-13-2014, 10:01 AM   #75
brent flynn
Sorry bout your converter... yea this is a blast! hehe
Old 04-13-2014, 11:35 AM   #76
Kegracing
Congrats Brent!
Sorry test did not go as well as planned, but you have a legal motor in the car, and at the track! Ton of hard work (and money lol) starting to pay off.
I will just keep watching and stay jealous! Maybe I will have the pile of parts put together one of these days for my 67 bird. Between weather and work, and son's Jr dragster, I have not even had my car out with the IHRA crate motor, let alone any work on the 400.
Good luck!
Ken
Stock 412
67 Firebird Convertible G/CM
Kegracing is offline   Reply With Quote
Old 04-13-2014, 03:22 PM   #77
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Update E-F/SA Bird Build...
Brent,
Sorry , to hear about your problems ... Take the time to re-check everything you can while you are down !!!! Valve springs, rockers, timing, carb, etc . Use the carb off your other car, go with parts you know already work ??? Then
change them back one at a time ? If you dinged a valve you would have some kind of miss, so keep looking ? Valve springs & Clearances are critical so keeping checking everything before you re-start ....Hang in there, you will be fine.... Good Luck
Dave Ribeiro 1033 STK
Old 04-13-2014, 04:10 PM   #78
brent flynn
Hey Dave...yea.. not what i was hoping for...but, doubt there is much damage... I will leak down, also, check carb, to make sure i didnt suck up something, after all the fuel system work... i did flush it, but you never know. Would be great if its just in the fuel system... but i'm doubting that ... will know more soon as i check compression...i have to get leak down guage from my buddy, but i do have a real nice compression guage, and it should point to a problem, if its big enough.... oil pressure is good, no leaks in the engine, and it fires right up, but you can tell it has lost a cyiinder or its running so lean, that its missing... will keep you posted!
Old 04-13-2014, 05:21 PM   #79
brent flynn
Well...found the problem(s)... #4 CYL is ZERO #s compression...tagged valve(s) for sure... so, taking heads off soon...getting different cam/lifters, and getting heads repaired and trying it again...hehe You cant tell that the car has any issues by lookin at this pic...hehe.
Probably gonna take awhile to get it fixed...im not giving up yet
Name:	Bird first time with 400 in pits.jpg
Old 04-13-2014, 06:22 PM   #80
HandOverFist
Well, that blows...I won't whine anymore about my problems. No doubt you will get it squared away quickly.
Rich Taylor
I/SA - 321
