Old 04-20-2014, 01:04 AM   #171
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
I seem to be in a perpetual snake bite loop with this car. One qualifying pass this morning and I was rewarded with a cracked transmission case. There has to be some misalignment or binding somewhere. Body bushings look tight and fine...going to investigate the motor mounts before another transmission goes back in. I marked the crack in the case so it would show better in the photo's.
Since I was pretty much useless for anything else I spent the day taking pictures and actually recorded every round. Too much video to upload in it's entirety, but I will put up part of a round and the final.
Due to my no-show for the first round Brian Rogers got a bye with his bad to the bone D/S 302 '69 Camaro...
Rich Taylor
I/SA - 321
Old 04-20-2014, 01:28 AM   #172
Geerhead55
Liked 5 Times in 5 Posts
Unhappy Re: '67 Camaro E/SA redo
Dang,, Rich I'm sorry to hear that this car is putting you through the ringer so much. You know eventually it will get down the track, but I know (heck, we all know) that its very frustrating at times. I just got done with a trans R&R 2 weeks ago and hated cutting my new ATI converter open to clean it all out. Hang in there, we're pulling for you.
Danny Durham
Old 04-20-2014, 01:58 AM   #173
HandOverFist
I'm on a mission now...I will figure this one out. Some video's coming shortly.
Love this car...
http://s434.photobucket.com/user/ric...634d7.mp4.html
The final...
http://s434.photobucket.com/user/ric...4e331.mp4.html
Rich Taylor
I/SA - 321
Old 04-20-2014, 07:28 AM   #174
Alan Nyhus
Liked 800 Times in 237 Posts
Rich, that's a darn shame. I was anticipating looking here this morning and seeing some positive results. No need to bore you with all the stuff to check....there was a good thread here recently on this same subject: http://classracer.com/classforum/showthread.php?t=52403
On the subject of motor mounts, I've got a set of Energy Suspension units to replace the solid mounts on my Nova before I take it out.
Have a good Easter and keep us posted, okay? -Al
"That'll never work....."
Old 04-20-2014, 08:41 AM   #175
HandOverFist
Yeah Alan...there is an odd match of motor mounts which bugs me a little, but I'm unsure if they have any role in the current problem. The trans mount is urethane.
Driver's side...
Passenger side...
This car was as smooth as silk before the rear housing perch failure...ever since that time there seems to be an odd vibration at different points on the track. I wondered if it was just my imagination, but the car just doesnt feel the same since.
I did replace the u-joints...how does one check the straightness of a driveshaft?
Rich Taylor
I/SA - 321
Old 04-20-2014, 09:21 AM   #176
Alan Nyhus
Rich, I would defintely get the driveshaft to a shop and have it checked for straightness & balance. It's hard to tell from the pics, but check the motor mounts and make sure there's not a mismatch of heights....there is a 'tall' and a 'short' motor mount. -Al
http://www.jegs.com/i/Energy+Suspens...1114G/10002/-1
Old 04-20-2014, 09:52 AM   #177
HandOverFist
I'll have to do some measuring today, but I think you are right about the difference in mount height just eyeballing it. I don't understand why someone would do that. I'll have to do some research for a local shop that can check out this drive shaft. Think those poly mounts would hold up?
After giving it some thought I believe I'm going to just go ahead and have a new drive shaft built and change over to 1350 yokes...no sense to keep pounding on this stock 45 year old shaft and 1310 u-joints. My only other decision then will be using poly or steel motor mounts.
Rich Taylor
I/SA - 321
Old 04-20-2014, 10:44 AM   #178
Robert Swartz
Robert Swartz's Avatar
Another thought from looking at the pictures. What kind of tranny mount are you using. Solid or rubber? You have a problem that can get maddening real quick.
Sorry, hadn't read all the thread, see you have urethane mount for the trans.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 04-20-2014, 10:47 AM   #179
HandOverFist
Urethane -
Rich Taylor
I/SA - 321
Old 04-20-2014, 11:05 AM   #180
Dan Nugent
Liked 3 Times in 1 Post
Broke a turbo 350 case in my Chevelle a couple years ago. I have steel mounts on engine and rubber on trans. My trans guy told me to make some spacer bushings at trans mount to leave a small amount of play in the mount -about a 1/16th. Had to open up slots in crossmember to fit. Trans guy does a lot of trans and anybody that has broken a case he has them do this with great results.
Dan Nugent H/SA N300
Dan Nugent is offline   Reply With Quote
