Old 04-20-2014, 11:59 AM   #181
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: '67 Camaro E/SA redo
Rich, the frame mounts are also different between small blocks and big blocks. It's easy to end up with a mismatch of motor mounts and frame mounts. And from side to side as things have been swapped around over the years. Generally, the dead give away is if theres a 1/4" spacer or stack of washers between the engine mount and the frame mount to compensate for the motor mount width...but not always. I've seen aftermarket solid mounts that are combinations of both dimensions. Here's some dimensions to help identify what frame mounts you have:
Small block:
Driver's side: 2- 9/16" tall
Pass side is 2- 3/4" tall.
Big block:
Drivers side: 2- 7/8" tall
Pass Side: 2- 1/2" tall
Basically, small blocks use the 'short/wide' setup and big blocks use the 'tall/narrow' setup. The '67-'69 Z-28's supposedly use the big block style (tall/narrow) setup....whew.
Just my understanding of it...... -Al
"That'll never work....."
Old 04-20-2014, 01:12 PM   #182
brent flynn
brent flynn's Avatar
I'd say it has to do with the rear end fiasco, when it wrapped up...i could be wrong... Sorry you having so many issues... I havent even gotten my heads off yet...maybe tomorrow eve...
Old 04-20-2014, 05:31 PM   #183
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
This was the qualifying pass which broke the case. Pardon the length...I'm just not into video editing today.
I'm going to install a torque link no matter what motor mount I decide to go with.
Rich Taylor
I/SA - 321
Old 04-20-2014, 08:46 PM   #184
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
sorry about the bad luck you are having.
I use urethane mounts on engine and transmission.
Energy suspendion mounts have a posi lock set up built in so they don't split apart.
I've bent solid mounts on engine 2x. I threw them in garbage.
I've used stock rubber engine mounts with a engine torque limiter on drivers side also.
a turnbuckle set up attached to frame on one side, cylinder head on other. works perfect and used by my friend who welded bracket to frame. He runs and builds stockers and index cars.
This is on A Bodies but same rule applies.
chris ok is offline   Reply With Quote
Old 04-21-2014, 01:05 AM   #185
Dion Hildebrandt
Dion Hildebrandt's Avatar
I fought something like this awhile ago, I kept destroying driveshafts and transmission cases.
Long story short the original driveshaft skip roped and one thing went undiagnosed through all repairs.....the transmission crossmember got bent downwards. The third instance we went and measured driveline angles and reset them back into a favorable set of angles. FWIW just my 2 cents
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-21-2014, 12:43 PM   #186
Dennis Banach
Rich,
Be sure to check the pinion for run out as well.... I`m betting the Driveshaft is the problem . Good Luck!
Dennis Banach is offline   Reply With Quote
Old 04-21-2014, 04:05 PM   #187
HandOverFist
New drive shaft being built along with 1350 yokes.
Rich Taylor
I/SA - 321
Old 04-21-2014, 04:56 PM   #188
Dion Hildebrandt
The best money I ever spent..
Old 04-22-2014, 01:15 AM   #189
HandOverFist
I don't know for a fact that there is anything wrong with the drive shaft...sent it to the builder to spin test it as they build the other one. It's about time for an upgrade anyway as there will likely be a hp/tq increase in the near future. I'm just trying to eliminate any weak links where I can...wearisome with all these breakages lately.
New low profile solid mounts ordered along with a tubular transmission crossmember.
Rich Taylor
I/SA - 321
Old 04-22-2014, 03:24 PM   #190
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: '67 Camaro E/SA redo
Hp/tq increase?? Are you thinking about one of the 396 combos, Rich?
Danny Durham
