Old 04-13-2014, 06:35 PM   #81
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
Will get it done as quick as possible... i figure another 1k will get me to better than before...as long as piston didnt get hurt, or worse...
Old 04-13-2014, 07:15 PM   #82
Alan Nyhus
Liked 799 Times in 236 Posts
Sorry to hear...at least the motors still in one piece. How much valve-to-piston clearance did you have? -Al
"That'll never work....."
Old 04-13-2014, 10:25 PM   #83
brent flynn
.100+
Old 04-14-2014, 09:28 AM   #84
bob3240
Liked 16 Times in 5 Posts
Bummer, Brent. If you need anything, let me know. Are all the keepers intact?
bob3240 is offline   Reply With Quote
Old 04-14-2014, 05:03 PM   #85
brent flynn
Yeah, Bob, i had valve cover off at the track, and keepers all looked normal... gonna rip intake and valley cover off tonight...will keep you posted...
Old 04-22-2014, 06:48 AM   #86
brent flynn
Removed heads, #4 exh valve bent, as suspected... only went to 5700-5800.
Pulling shortblock tonight, to check #4 bearing, and make sure its not passing anything, as the filter was pretty clean, but, lifters already showing wear. Cam still looks fair. Also alot easier to degree cam, and i have a pan bolt, along passenger side, that is leaking a bit...( a first for me) ...Chris at Comp is gonna be working on a new grind for me, and we will figure out springs and lifters...Hope to be ready for testing, before Joliet.... fingers crossed...Piston had very small spot on it...
Old 04-22-2014, 09:51 PM   #87
brent flynn
Cool Re: Update E-F/SA Bird Build...
It's not lookin' good for the home team.... I took the shortblock out of the car, removed pan, checked a couple bearings, and its obvious that ive had alot of material go through the oil system... the filter wasnt showing alot.... crank will get by with a polish... but looks like i will need to start over, as i will have to give block another cleaning, and probably a touch up on the hone, even though the cylinders look fine... Apparently, Rich(Hand Over Fist) and I , arent supposed to get down the track , this season...
Old 04-22-2014, 10:01 PM   #88
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Dammit Brent...we will get thru this and come back stronger. Anything you need if I have it it's yours.
Rich Taylor
I/SA - 321
Old 04-22-2014, 10:06 PM   #89
brent flynn
thanks Rich...we will get there... Please tell me that you have a d-port combo, ready to go...i will pick it up...
Old 04-22-2014, 10:13 PM   #90
HandOverFist
If I did it would be on it's way to you buddy.
Rich Taylor
I/SA - 321
