Old 04-17-2014, 09:44 AM   #71
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Nova stocker project.
Just an update: It runs, moves under it's own power, the oil and water stays in the motor and none of the wiring went up in smoke. Also upgraded the driveshaft to a chome moly unit with 1350 series yokes and joints. It's off to the alignment shop next week. -Al
Looking forward to seeing it go down the track Alan.
Rich Taylor
I/SA - 321
Old 04-22-2014, 10:56 PM   #72
Alan Nyhus
Liked 800 Times in 237 Posts
Back from alignment...front tires pointing where they're supposed to:
"That'll never work....."
Old 04-22-2014, 11:07 PM   #73
HandOverFist
Get it down the track Alan...one of us has to succeed lol!
Rich Taylor
I/SA - 321
Old 04-26-2014, 03:35 PM   #74
Kelly Petterson
Kelly Petterson's Avatar
Liked 3 Times in 2 Posts
Thumbs up Re: Nova stocker project.
Like!
Originally Posted by alan nyhus View Post
back from alignment...front tires pointing where they're supposed to:
Kelly Petterson 5781 B/SA
Kelly Petterson is offline   Reply With Quote
Old 05-03-2014, 09:48 PM   #75
Alan Nyhus
Made 5 runs today. Had a few glitches. The Line Loc solenoid developed an internal short and blew a fuse each time...so much for anything resembling a decent burnout. On the last run, the starter acted wonky in the lanes. I went to the scales after the run and the starter drive hung up in the flex plate and wouldn't retract. But all in all, nothing too drastic.
The car drives smooth, goes straight, stops well and no parts fell off. It wasn't real fast, though...barely two tenths under the NHRA G/SA index. The car feels really 'tight' when it leaves...like maybe the convertor is 'way to tight? I checked the 'flash' on the return road a couple of times (in high gear about 20 mph) and it flashed between 4400-4500. Not where a combo like this should be...
All in all, not a horrible start. -Al
Old 05-03-2014, 10:05 PM   #76
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
What did it E.T. before you bought it?
Old 05-03-2014, 11:10 PM   #77
HandOverFist
Sounds like not near the problems we are having Alan. Car looks great and I'm sure you will get it sorted quickly.
Rich Taylor
I/SA - 321
Old 05-04-2014, 10:23 PM   #78
Alan Nyhus
Virtually identical times, Glen. The convertor is the big unknown. Heck, I'm not even sure whose convertor it is,though I do have all the code numbers that are stamped on it. -Al
Old 05-04-2014, 10:43 PM   #79
HandOverFist
I'm learning all the stars must be aligned with these Stocker's...one piece out of whack and it all goes to hell it seems.
Rich Taylor
I/SA - 321
Old 05-05-2014, 06:13 AM   #80
brent flynn
brent flynn's Avatar
Ditto!
