Old 05-09-2014, 10:54 AM   #221
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Originally Posted by modelman1960 View Post
Hey Rich, I saw a while back that the Fazio family posted video of their SS/L Mustang launching to get advice about the launch and the suspension movement between gear shifts. They mounted the camera under the back of the car and got it so both shocks could be seen. Then made a pass. They had an answer about the issue real soon from this website. Just suggesting camera location may be more helpful than putting it on the body. I may also be completely out of order too. Just trying to help Sir.
Good luck with this way cool Camaro.
Walt
Thanks Walt - I had very good footage of the suspension...it's just that it was the very first time I had seen the car from that vantage point and it didnt immediately click what was happening. I had already made the decision to swap the shocks before finding out about the body separation. At any rate the next outing I will have video from both under the car and exterior.
Even with the less than ideal set-up you could actually dial/race it as it was. Back to back runs in the heat with poor air and I short shifted the final pass...
Rich Taylor
I/SA - 321
Old 05-18-2014, 10:48 PM   #222
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, how did things go today? -Al
"That'll never work....."
Old 05-18-2014, 11:11 PM   #223
HandOverFist
Well, let's see...I flubbed both time trials, had no clue for first round and went red for a SS/BA 9.teens opponent lol. How was your day?
I've just about pegged this on the convertor going south. How else does a car go from 1.45 60' to this? Funny thing is it is consistently bad and the et's get quicker. It sure is messing with my lights. The car just doesnt have that "snap" any longer at launch...we are going to do a convertor swap to confirm. Thinking maybe the convertor is tightening up, slipping less resulting in the decrease in et and more mph???
Rich Taylor
I/SA - 321
Old 05-19-2014, 11:23 AM   #224
HandOverFist
Only thing I see is the convertor just doesnt flash...like it's just driving off the line. If anyone can point anything else out be glad for the input.
Rich Taylor
I/SA - 321
Old 05-21-2014, 10:28 AM   #225
HandOverFist
Just got the word this morning the convertor is good. Had it cut open and no problems were found...they will loosen it up a little more before putting it back together.
So...the transmission must be slipping. Partner says the fluid smelled burnt when he pulled the convertor out...will just have to take it back to Thomas I guess.
Rich Taylor
I/SA - 321
Old 05-21-2014, 10:48 AM   #226
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: '67 Camaro E/SA redo
Rich,
How fast did you go with the old slapper bar set-up ??? That's where I would start to look, something isn't right ?? Just my two cents, worth checking out ... You can check the tranny & I hope that's the problem, but if it's not ???? Good Luck, keep us updated .?
Dave Ribeiro 1033 STK
Old 05-21-2014, 11:09 AM   #227
HandOverFist
Originally Posted by Dave Ribeiro View Post
Rich,
It was only going 7.40's with 1.50 60' when it still had the Powerglide and Caltracs.. It did 7.19 with a 1.45 60' with the metric 200 and Caltracs. We never really ran the car ourselves with the old slapper bars. Since we got the trans back it has never had a 60' better than 1.52...thus the reason for us to suspect the convertor. I really can't see it being anywhere else other than the transmission since the convertor has been opened and verified good.
1.54 60' on this pass...
Rich Taylor
I/SA - 321
Old 05-21-2014, 03:00 PM   #228
John Musial
Liked 51 Times in 3 Posts
Rich you have a PM.
John Musial is offline   Reply With Quote
Old 05-21-2014, 04:31 PM   #229
madman9
Liked 3 Times in 1 Post
how much did the metric200 pick yours up thanks
madman9 is offline   Reply With Quote
Old 05-22-2014, 01:43 AM   #230
HandOverFist
That would be hard to guesstimate in our case. The car originally had a Powerglide in it so the difference was drastic. I'm told the gain from a metric vs a good running TH350 combo would be at least a tenth.
Rich Taylor
I/SA - 321
