Old 05-27-2014, 04:40 PM   #1
HR 9505
Default Older Hipster Pro Brake check balls
I just took apart an older Hipster Pro Brake valve body and had a check ball to fall on the table and I can not figure out where it goes. I have a white plastic ball in place but there was a black ball also. Can anyone tell me where the black one is supposed to go?
Thanks,
Jason
HR 9505 is offline   Reply With Quote
Old 05-27-2014, 05:53 PM   #2
HR9121
HR9121's Avatar
Default Re: Older Hipster Pro Brake check balls
Uh ruh roh! Sorry bud can't help you there buddy but hopefully someone will chime in.
James Williamson
W200 J/SA. SS/JA
Old 05-27-2014, 08:58 PM   #3
FED 387
Liked 335 Times in 182 Posts
262-251-7777 give em a call might answer ATD but they are or were Hipster
Old 05-28-2014, 08:12 AM   #4
HR 9505
Thanks FED 387!!
Old 05-28-2014, 03:54 PM   #5
HR 9505
Update:
I called the guys at ATD and they confirmed that the black rubber ball goes between the white ball and the aluminum sealing plate. Thanks guys for the contact info!
