Liked 6 Times in 4 Posts
Looking to make the jump from foot brake to trans brake (T-400)... I want to do this right the first time... Is there a solenoid location preference?
I'm a high 9's bracket racer, if that matters..Any trans brake info that you have,...... (what to look for, what NOT to look for) you can share with me would be greatly appreciated TIA. |
Liked 5 Times in 5 Posts
I don't know what brand your T-400 is, but you might start by talking to one of the manufacturers,, mine is a Coan, but its a Powerglide so the circuitry is different. They could guide you to a decision on wether an internal or external system is better for your application. By the way, my solenoid is external and I don't have to activate the trans brake to back up like some others do. I'm sure Coan, ATI, TCI, or any racing trans builders out there can help. Good luck with your choice.
Danny Durham |
Bob, I ran a J W in my 400 and of course a Coan in my Coan 350. Have been pleased with both of them. Oh ya, forgot to tell you they were both external mounted.
Liked 886 Times in 238 Posts
I've both built for customers and used TH400's myself with a variety of transbrakes
For release quickness and shift quality the Griner internal valve body cannot be beat . Most of the external brakes are similar in operation and are ok , but none compare to Griners valve body .
Liked 2 Times in 1 Post
X2 on the Griner Brake. I have used one for years. It is an internal solenoid for quickness. Can be hard to get one although I think they are introducing new products.
Bob |
The TH400 internal brake that ATI sells is a Griner.
Liked 20 Times in 3 Posts
If you are bracket racing go with the external, it will cool much quicker than the internal. The internal is not designed for back to back round racing and will get hotter more easily than the external.
Having used both the ATI internal Powerglide brake and the Griner internal TH400 brake ,I can tell you the ATI will change about .015 after about 3 hot laps.
The Griner on the other hand did not vary on bit hot lapping, probably due to the physical size of the solenoid valve and the passages. The ATI unit is obsolete, I sold about a dozen take outs to mud racers , perfect for them !
