#281 |
Liked 107 Times in 35 Posts
I applaud your experimentation with the acc. pump and have done a considerable amount of tinkering myself with very little success. That light spring scares me, though, as the purpose of the accelerator pump is to give a very quick shot of fuel before the main wells and/or power valves get "in the game". Squirter size is another consideration, but on a q-jet not particularly important.
A more important consideration is the choke pull off rate of release in conjuction with the air valve tension (and angle) and being able to adjust them quickly and easily. Also, I have fought some q-jets that seem to defy all logic and not work in spite of a lot of effort. Sometimes, you just have to set them aside and get another core. Good luck, Ron. |
#282 | |
Liked 33 Times in 16 Posts
![]() Cliff Ruggles is sending me some adjustable pull offs and the air door settings will be the normal trial and error scenarios. I'm just so happy to be at this point of actual tuning finally instead of breaking parts. ![]()
Rich Taylor I/SA - 321 |
#283 |
great! you got ahold of him... cant wait to hear how it all works out...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#284 |
Well, I have three ready for battle...I hope. Taking the car to a bracket race July 5th and hopefully one will get down the track.
#285 |
Your secondaries about 1:1? Worked great on big cube engine... feels good on the 400, but 4.30 just aint enough gear...
#286 |
Brent - If you mean have I messed with the secondary opening rates that would be no.
#287 |
Nothing better to do today so I took the remainder of my spare Q-jet parts and cobbled together one more carb to take to the track. The main body is a 207 and the rest of it from carbs unknown....145 inlet, 67 primaries and CL rods on a K hanger. Would'nt it be a hoot if this turned out to be "the one" ?
![]() ![]() Going to attempt to tune out any air door bogs on our concrete apron outside the shop on all the carbs before heading to the track.
#288 |
Liked 71 Times in 23 Posts
I always lied a loose air door and fast pull off, as long as it don't bog you'll be fine. If it bogs tighten door like, or slow down pu off ti it goes away.
Monte Howard 3209 STK, 3208 SS |
#289 |
I really saw a difference goin from standard linkage to almost 1:1 ... it was roughly .02-.025 in 60'...maybe a little more when the air was real good... i wouldnt go back the other way, again...it should really come out good, with the 4.88s ... Did you get some of Cliff's acc pumps?
#290 |
Semi-homemade on the pumps. I will have Cliff's pull offs in the morning.
