Old 07-07-2014, 09:32 AM   #1
targus
Default Inconsistency
Is it possible for a converter to cause an issue where my car will make 3 or 4 passes within .04 of each other then out of nowhere make a pass that is .2 slow. On the pass where is slows down it loses ET everywhere starting with the 60'. Everything has been changed on the car trying to solve this issue, wiring, MSD, coil, fuel system, etc... I am of the assumption that if something was wrong in the converter it would continue to slow down, where as once I load up after making this slow pass, the next time to the track the car is right back to making good passes.
3000 lbs car
540" BBC
Ladder Bar Rear Suspension
Powerglide
I installed a data recorder to track engine RPMs this past weekend and on the two passes where the car fell off, the RPMs are very shaky from about .07 into the run. I will try to post a picture of the graph later.
targus is offline   Reply With Quote
Old 07-07-2014, 07:32 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Inconsistency
post up all the time slips in order from the day in question.
That said, moving .04 in 3 or 4 passes is a problem no mind 2 tenths.
Consistency starts and end with the one wearing the brain bucket. Are you doing everything exactly the same from the moment you buckle your harness to the moment you cross the stripe?
Old 07-08-2014, 05:45 PM   #3
Ed Wright
Ed Wright's Avatar
Too rich makes it too sensitive to temp and Baro changes.
Ed Wright 4156 SS/JA
Old 07-08-2014, 07:25 PM   #4
targus
I pay extra attention to my routine for consistency, especially since these issues have come up.
I have the RPM graphs saved as pdfs but am not sure how to post them.
I do not think it is jetting just for the fact that no big change in weather has to happen for the car to make a slow run. No matter what the weather does the 4th or 5th run will be .2 slow and if we make any additional passes after the slow run they are slow as well.
Old 07-08-2014, 09:35 PM   #5
1320racer
1320racer's Avatar
again, post the time slips in order from one day.
Old 07-11-2014, 01:48 PM   #6
Lee Valentine
Liked 319 Times in 68 Posts
Had a car do that once, had one broken roller in converter sprag.
Lee Valentine 1661 STK
Old 07-16-2014, 12:14 AM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Targus, In the submit reply window, top row, there is a paper clip next to a smiley. Right click that & a window opens with a button to browse your computer for the files you want to upload & in the lower right of that frame an upload button. That said, I have never been able to upload a .pdf, only a .jpg or .bmp. Can you save the file differently ?
1320, how bout we help with his upload issue 1ST.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 07-16-2014, 02:46 PM   #8
targus
Attached are RPM graphs with the red line showing a "good" pass and the black line showing a "bad" pass where is slows .2
Name:	7-5-14 Run #3 and 4.JPG
Old 07-16-2014, 10:22 PM   #9
Dave Noll
Dave Noll's Avatar
I haven't had the privilege of reading many of these graph's but with the black line rough, does the engine have an intermittent miss ?
Old 07-17-2014, 02:34 PM   #10
targus
There is not a noticeable miss. With the lower stall of the converter you can feel that it is on a lazy pass. The up and down movement in the black line equals about 100 RPM.
